peter1480
I just received my F5s a couple of weeks ago. After months of enjoyable use of my X5III, I'm starting to have a bit of trouble with it today. I'm listening to it using my F5 IEMs with the balanced cable and I'm finding that the left channel keeps cutting out with the slightest movement of the player or jostling of the cable. If I replace the balanced cable with the SE cable, things seem fine which I think rules out a problem with the IEMs themselves. Sadly, I lack a second balanced cable to test with nor do I have a different device with a balanced output. So I can't determine if the problem is with the F5's cable or the X5III balanced port at this point.
I can say that the issue is at the connection. I can rotate the IEMs on on the MMCX connectors with no issues but as soon as I touch the 2.5mm TRRS plug or wiggle the cable near the connector end, the left channel drops out.
Has anyone else had any issues with the balanced port on the X5III or the one of the audio channels on the F5 cutting out on them?
I've gone throught probably a dozen or more MMCX cables over the last 5-6 years. It happens. You can probably get it replaced via the warranty at this time. I'd send a message to fiio - they have very good support. I doubt it has anything to do specifically with the fact that the cable is balanced but I could be wrong.
Same here, MMCXX cables and 2.5mm TRRS, according to one manufacturer I use, are difficult to get good connections on as the area avalable to solder to is so small. In contrast my XLR cables last for around 10 years. Perhaps that's why Sony have gone for the super sized balanced connerctors on their high end players?
