FiiO E6 - story of the tiny amp continues... (w/ review on 1st page)
post-7673589
Post #31 of 611
ClieOS
IEM Reviewer Extraordinaire
Middle of Johor, Malaysia
Website
InEarMatters.net
ClieOS, how would this compare to a cmoyBB?
Also, have you paired the E6 with an Xcape IE? I find the IE to be good straight from my Fuze, but it does need fairly high volume.
Hoping something small like an E6 could take the xcape to a higher level. Maybe more bass definition and soundstage (with LOD from Fuze)?
I did a quick A/B with E7 and cmoyBB. I find that the E6 is a tiny tad more revealing and less warm that E7, otherwise they are very similar. As for cmoyBB (on default opa2227), it has a warmer, richer, more expensive layer of soundstage, but other than that, the performance is comparable. I would say E6 is right between E7 and cmoyBB (which I think is already pretty close in performance, though different in flavour). It won't win cmoyBB, but I think the gap is smaller than the price difference between them.
post-7673926
Post #32 of 611
Parall3l
lƐllɐɹɐԀ
This looks great
 Almost missed this little amp, should work well with my DAP.
post-7673969
Post #33 of 611
ubercaffeinated
westone's web site is already showing "AMP'D" versions of their universals, but doesn't say anything about the E6... yet.
post-7674070
Post #35 of 611
ClieOS
Website
InEarMatters.net
If you look at the W2 AMP'D, it says 'Westone E6 amp by FiiO' in the description.
post-7674846
Post #36 of 611
Jack C
Previously known as Jack-Micca
Member of the Trade: TekFX
I eagerly await ClieOS's review on this new little amp.
As ClieOS mentioned, this amp was "ready" quite some time ago. In fact, you can see some mention of a E5 replacement in Head-Fi forum history many months ago. This time around FiiO addressed some of the main wishes that people had with the E5: more gain, more EQ choices, and more original aesthetics. I believe the overall ergonomics is a huge step up as well, and the quality of the bundled accessories also received a significant upgrade.
FiiO indicates that the E5 will stick around as they have different plans for the E5 and the E6. While most consumers will probably find it worthwhile to go for the E6, the E5 remains a mature product with a lot of value and market recognition. I am guessing this is kind of like how you can still buy a Sony PS2.
Jack
Reactions: Riku540
post-7677332
Post #37 of 611
phntmsmshr
How would you say it compares to SoundMAGIC A10 in terms of clarity? I have found that the E5 didn't bring much to my sources or IEMs but A10 pulled some really nice clear signal out of my iPod.
post-7677510
Post #38 of 611
ClieOS
Website
InEarMatters.net
E6 is more revealing when it comes to micro detail. With A10, you'll get more texture on lower end and body, that's because A10 is inherently a warm sounding amp with a colored FR curve. If you are looking for amp with a warmer, richer tone, cmoyBB with an upgraded opamp is probably the best option for you.
post-7680817
Post #40 of 611
Armaegis
Modern Modder Man of Manitoba
HTML... uphill, both ways!
Just a thought for future designs, shape the clip so that it easily clips onto other daps. Back in the day I had an e5 and Sansa Clip and I would just snap the respective clips together and put it in my pocket, but the clips didn't quite line up right so it wasn't as compact as it could be. Just a minor thought.
post-7680856
Post #41 of 611
kanuka
very nice!
so, have you tried it with some high-impedance like the er4s, re262, pk1? or even the RE0 ?
post-7682141
Post #42 of 611
ClieOS
Website
InEarMatters.net
very nice!
Yes, I have tried them, just not the PK1 as I haven't used it regularly these days. Overall it pairs better with the warm sounding RE262 than ER4S/RE0 synergy wise, though it is able to drive them all to very loud. With teh colder sounding IEM like ER4S and RE0, I tend to use it with the EQ.
post-7682286
Post #43 of 611
kanuka
but i guess, it cant get the 100% out of  them like the E11does, right? but still, sounds much better like the E5
post-7682322
Post #44 of 611
ClieOS
Website
InEarMatters.net
100% is a tricky word. If it is by pure driving power, no, E6 isn't as powerful as E11. But as good as E11 is, there are still better amp that can drive RE262 / ER4S / etc to higher level.
post-7682902
Post #45 of 611
stupid11
how is the staging of E6 itself? can it really add the soundstage depth of IPod video???(i.e. increasing the presentation of soundstage layer)
how is the sound quality of E6 itself compared to E11? is E6 brighter than E11??? because it seems that E11 is too dark for me....
thx~~
