fiio e6 replacement battery ?
Discussion in 'Portable Headphone Amps' started by steelgtr, Jan 26, 2015.
  1. steelgtr
    Didn't use it for a while and it won't charge at all. Any ideas on where to get a replacement?
    thx
    bob
  2. ClieOS Contributor
    The original Li-ion battery is 160mAh, around 30mm x 17mm x 4mm in size. You should be able to find a suitable replacement on eBay with a smaller capacity, like this one. However, you need to know how to solder to replace the battery. Also, the case are glued together, so you need to pry it open, but it isn't very hard to do.
  3. steelgtr
    Thanks, You did better than me;  I bought this one and it's way to thick:
    http://www.amazon.com/gp/product/B004KGTM90/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
    I'll just leave some of the old wire and splice in the new one.
    Thanks!
    bob
