Anouk
- Jul 8, 2008
Will be interesting to see if this iwll work with the nexus 5 when it comes out.
Going to bring the PRO-900s for the commute. Let's see what it does there.
Have you used it while moving across signal zones? If you're just listening to it at your desk, you're not going to get any interference. The interference occurs from the signals the antennae emits when attempting to regain signal, send/receive large amounts of data, etc. Use it as a portable player while going in and out of a dead zone. If you really have no problems, then let me know, perhaps I got a bad unit?...
I use my E18 as a portable just as much or more than with my laptop and I have never come across the buzzing problem...
I've been doing a lot of reading here, and it looks like Android has had the functionality for a while, and indeed is working on the S3. It looks like Samsung is the cause of the S4 issues.
I think I was wrong earlier when I bashed Google for the Galaxy S4's inability to act as a host for USB DACs.
So it looks like this may be carrier specific.
I just got my E18, plugged it into my S4 (yes, USB in), and it works straight away through Poweramp, Noozy, and the Youtube app. When I plugged it in it turned the volume on the phone all the way down and I just had to turn it up.
However, I happen to have another S4 here for testing (I'm a mobile software tester) through T Mobile, and it is NOT working on that one.
My phone is rooted but still stock (the testing device is, of course, fully stock). I have ViPER4Android and Noozoxide installed but disabled. It works with Poweramp set to use direct volume control or not. Noozy says that it failed to initialize EMU due to unsupported DAC (which it does without the E18 as well). Unfortunately I can't change much on the S4 for testing because it needs to remain as close to being OOB as possible. I also have personal stuff going on today that makes it unlikely that I will be able to do much more today, but we'll see. I'm happy to do whatever I can to help you out, cswann1.
So I'm very glad to be at least partially wrong, though I still think that Fiio needs to be more up-front about this.
I am a little weary about this OTG cable; it looks like something that will short out after a month of my bus commute.
Not working on My Verizon S4, but I can, for example, use my Hifiman HM-101 with the same phone, so....
My S4 is also rooted, but generally stock otherwise. Very disappointed with the E18.
