Fiio e17 or bravo audio ocean valve?
Aug 17, 2013 at 4:37 AM Post #2 of 28
Not even comparable. Bravo is much better.
Aug 17, 2013 at 11:16 AM Post #4 of 28
It is good value. Indeed G3 is better but difficult to change tubes.
Schiit magni is the ss equivalent.
Aug 17, 2013 at 5:39 PM Post #5 of 28
Hi. I need a good amp that I can use at home with my 558's and iPhone. Which one is better? Can find both at same price.
The HD558s are only 50-Ohm and the Fiio E17 is way more useful then the Bravo.
So I say get the E17.
Aug 18, 2013 at 1:00 AM Post #7 of 28
How is it more useful?
Chances are the E17 headphone output impedance is way lower then the Bravos.
Which should help with audio detail on the HD558s.
The E17 comes with a fairly good built in DAC (WM8740) chip.
The Bravo has no DAC
Aug 18, 2013 at 2:11 AM Post #8 of 28
Even for low impedance headphones bravo is better. I have tried it.
Aug 18, 2013 at 12:18 PM Post #11 of 28
Hd558 or pioneer SE a1000. Also depends on your taste and music preferences.
Aug 18, 2013 at 1:31 PM Post #12 of 28
Aug 18, 2013 at 1:36 PM Post #13 of 28
Aug 18, 2013 at 1:43 PM Post #14 of 28
