But:
Here're some notes from @ClieOS from earlier in the thread:
OPA627 + BUF634 for warmth and smoothness
Is it a stock op-amp, right? So, as I read in this thread stock op-amp is best, and I can not use MUSES. Right?
OPA627 isn't stock, you'll need to get it and solder it onto one of those spare adaptors. As for whether you can uses the MUSES, Try popping in a DIP8 opamp first to see if the case can slide shut without filling/grinding. It so happened that mine was one of the lucky ones so I was able to use OPA2227, TLE2082 and JRC4556. A bit of a squeeze but that was it.
