Danthuyer
- Sep 8, 2013
Hey Peeps,
My E12 is getting onto about 4 years old now and has put in some solid hours and worked very hard during this time. Lately I feel the input/output jacks might be suffering from too much usage and I can hear slight distortion at times and or the balance becoming uneven. I find if I move the input cable or output cable it helps.
This occurs with multiple headphones and sources so I'm pretty certain is the E12.
So is it work looking at fixing the Amp ? or should I look at just retiring it to the shelf and looking at a newer, better portable ?
Cheers in advance
Dan
Cheers in advance
Dan
