[FiiO BTR7] Portable Bluetooth Amplifier, Color IPS display,High-performance DAC ES9219C*2,THX AAA-28*2 amps,3.5+4.4mm outputs,One-click “dongle” mode
Aug 16, 2022 at 1:22 PM Post #466 of 2,064
Since FIIO did not include a clip or other way to carry the BTR7 I thought I would share this simple DIY fix. You can take a common household Fork and push your favorite chain or cord through the back of the included leather case and wear the BTR7 around your neck. Hope this Helps :)
Lasher
Just wanted to add this also
Aug 16, 2022 at 1:58 PM Post #467 of 2,064
So I am a health care worker by trade. I use them little extension key fobs all the time for my clinic ID. Hence I know the problems/ limitations with those things. They break all the time. I would think twice about using that. Those are more flimsy than you would imagine. I like the chain idea provided by @LasherV much more so than using one of those. Unless that has a cord made of some type of impervious strong thread but even then the part that breaks easily is the plastic snap portion. That cracks in a matter of a few months of use. I would think twice about using the BTR7 that way. Just a bit of a warning.
Aug 16, 2022 at 2:04 PM Post #468 of 2,064
So I am a health care worker by trade. I use them little extension key fobs all the time for my clinic ID. Hence I know the problems/ limitations with those things. They break all the time. I would think twice about using that. Those are more flimsy than you would imagine. I like the chain idea provided by @LasherV much more so than using one of those. Unless that has a chord made of some type of impervious strong thread. I would think twice about using the BTR7 that way. Just a bit of a warning.
I am in the same field, been using this for over a year to hold my badge and other things without any issues around my neck 12 hours a day so it's pretty sturdy imo.
Aug 16, 2022 at 2:11 PM Post #469 of 2,064
If you think that is ok than it is ok but I am just saying that is not my experience with them. You also gotta consider BTR7 bulk, size and weight compared to a simple ID card. For a portable device a lack of a strong clip on the case is quite puzzling. It is so obvious that is what that case needs but hey now we got to resort to self modding. I hope Fiio considers a clip on the case and I don't think it would be that difficult to come up with one.
Aug 16, 2022 at 2:17 PM Post #470 of 2,064
I'm sure Miter will make one soon.
Aug 17, 2022 at 1:28 AM Post #473 of 2,064
Hopefully if not FiiO themselves.
How did they envision its usage on the go with case like this? 🤷‍♂️
This is the intented use case scenario from FiiO,
1. Hold the device with one hand and enjoy your music,
Oh, you doing something with your hand?
Then you are out of luck,
2. Put the device on your desk,
This is how I use it,
Clip it on my pants for a morning bicycle ride, when I'm at the gym, doing chores, playing games, posting in a FiiO thread, etc,
Aug 17, 2022 at 4:51 AM Post #475 of 2,064
Another issue I think i discovered when I change to 88.2khz ldac on developer settings music doesn't work I get strange jitter click sounds out of the BTR7.. I can't get that sample rate to work all others I can change to.
I also still can't change the 96khz ldac display on the btr no matter what sample rate I change to on phone it always says it's 96khz ldac which shouldn't be the case (Qudelix for example comfortable changes sample rate to match device ldac)
The same on 88.2 KHz.
Try this composition (at 1.33-1.34 or 1.55-2.05) with developer settings "defaullt 96"- crispy sound. Ears are bleeding... But in 44.1 or 48 anything is ok
I'll confirm this with the technician team, I'm sorry for the trouble..
Aug 17, 2022 at 5:01 AM Post #476 of 2,064
@FiiO last night I used the wireless charging and I let it on the charger all the night. This morning I took my btr7, it was very warm like 30 celsius.
Is there any features who stops the wireless charging when it's full maybe a firmware update soon??
We have confirmed this issue and will change it in a subsequent firmware :beerchug:
Aug 18, 2022 at 3:29 AM Post #479 of 2,064
@FiiO please bring more granular settings for EQ in App just 5 FR settings are too basic any chance we can have Peace Equalizer level detail settings.
Dear friend,
Would you mind sharing the example of the PEQ you would prefer to us as well?
Best regards
