skreddy
- May 9, 2011
So I can get 96k to work on my PC but through my phone the same track shows up as 48k. Any idea why this could be ? Could it be the USB cable ?
Ok, thanks for the kind feedback.Just tried USB Audio player and same thing. It says the source is 96khz but the dac is 48khz.
Edit: NVM that was Tidal without purchasing MQA decoding. Works with FLAC files on phone.
@FiiO any news on a possible firmware update using Mac or an iPhone? I am stuck with an old Firmware. I already tried the alternative tutorial you suggest from the support forum but to be honest, it is quite complicated and it did not worked for me. It does not even work using a virtualization software like Parallels! To be honest, this makes no sense! Specially now, during the pandemic, where we cannot use other persons computer....
Sorry that the chip supplier doesn't provide the tool for updating the firmware in MAC for us currently. So it is out of our ability to provide the firmware update for MAC now.@FiiO any news on a possible firmware update using Mac or an iPhone? I am stuck with an old Firmware. I already tried the alternative tutorial you suggest from the support forum but to be honest, it is quite complicated and it did not worked for me. It does not even work using a virtualization software like Parallels! To be honest, this makes no sense! Specially now, during the pandemic, where we cannot use other persons computer....
I had trouble with v2.1 as well. Maybe that's why it's not officially out for updates. Only new units come with it. I'd go ahead and download the firmware updater and v2.0 and I would downgrade.So...
I recently acquired a new btr5. I like it when it works.
I mostly use it for bluetooth and the trouble starts when I plug into my pc to charge it.
After being in usb mode it won't go back to bt mode unless I leave it overnight. After disconnecting from the pc and powering it will come on and quickly say "off" and shutdown.
Holding the power button for 10 seconds does not help and the multifunction button often does nothing.
If I leave it sit overnight bt will start working again the next day but the battery will be low again. Not a great situation for me.
Also the unit report the version is 2.1.
Any suggestions?
I move to v 2.0 this afternoon. So far it seems to work as expected now. Thanks for the suggestion.I had trouble with v2.1 as well. Maybe that's why it's not officially out for updates. Only new units come with it. I'd go ahead and download the firmware updater and v2.0 and I would downgrade.
Dear friend,So...
Any suggestions?
As far as I know it was set for power on. I have never switched it off.Dear friend,
Thanks for your feedback. We will report to the tech team for checking about that as well. You were charging the BTR5 in power on or off status when the issue happens?
Best regards
