Hamlap
I had the tripowin balanced before I got the blons. Pretty decent cable for the $ imo.
Got any links for those guysHave a cheapo £15 balanced coming tomorrow for the K10U.
Might be crap (Amazon UK)Got any links for those guys?
BTR3 nothing special and I had BT issues.
BTR5 on par with a great DAC/AMP and best BT.
I have blon 3 and it's an awesome pairing. It sounds like a top end dap out of balanced. 3.5 is good too, but balanced sounds really nice.
Was covered further back I think. Once driver is installed the likes of Tidal/Spotify/AmazonHD play at tracks standard rate (And BTR5 screen shows it too).
So you'd say it's definitely worth the upgrade to go balanced for the Blon?
Alright! It appears that I already have a balanced cable, haha! Just a 3.5mm one... Any good adapters?For the small price of the cable I'd say yes, the balanced has a bigger stage and everything is tighter. Of course the blon doesn't need the extra power, but even at the same relative volume you get more headroom. It's not night and day, but it's noticable.
Thanks! Could also just order an extra cable with 2.5mm for that priceI have this one, well the opposite version of it anyway. It works well for my usage:
https://www.amazon.co.uk/gp/product/B07PDR4XSX/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
Thanks! Could also just order an extra cable with 2.5mm for that price!
