soumyajit92
Hi guys, why does audio over LDAC sounds so bad compared to USB connection on my btr5? Is it android messing with signal processing? Isn't btr5 supposed to process the signal? The reason i have my doubt is that whatever processing i am making through my phone (hiby mseb or eq using wavelet, just to check. they are left at default otherwise) is being reflected over bluetooth. So wondering if android's audio processing,which it is notorious for, is really messing with the quality before sending it over to the dac? A few people in a fb group told me that ldac and sound over usb should sound almost the same but there's a huge gap between the two using my phone. So is it my phone or my device is faulty?
PS: I know usb ll always sound better than wireless but the gap shouldnt be this big on btr5 which is famous for it's BT quality or so i had heard. What am i missing?
