[FiiO BTR17/BTR7] True Lossless Bluetooth, Portable Bluetooth DAC and Headphone Amplifier BTR17 Is Officially Released!
Dec 15, 2024 at 11:50 PM Post #2,566 of 3,183
My BTR17's knob is wobbly too. This might the failure point / weakness to the BTR17's build.
Someone from FiiO replied to me stating it was a design decision rather than a weak point in the device.
Idk, it's fine as long as it doesn't break 366 days from the time of purchase lol
Dec 16, 2024 at 12:01 AM Post #2,567 of 3,183
Video? How wobbly? Mine's fortunately pretty solid.
Dec 16, 2024 at 12:55 AM Post #2,568 of 3,183
Dec 16, 2024 at 12:57 AM Post #2,569 of 3,183
LOL of course FiiO themselves will say it's intended to be this way, so they won't have to take responsibility for broken units, complaints, or dissatisfied customers.
Fact is, I got a loose knob BTR17 and so have others.
Dec 16, 2024 at 1:02 AM Post #2,570 of 3,183
CeThis is not to defend fiio but all the units I've had with a rotary button (ifi go blu, ibasso dc07 pro) had this wobbly side at the button level. I don't find it shocking. Now this kind of button that you can press and turn are clearly more fragile than a classic button or a simple volume wheel. But I find nothing shocking at this level.I think it's even more practical. I wouldn't worry about that.
Dec 16, 2024 at 1:12 AM Post #2,571 of 3,183
Dec 16, 2024 at 3:18 AM Post #2,572 of 3,183
Mine is the same, I would not consider that slight play as concerning.
My iFGi Go Blu has slightly less and both my A&K HB1 and Hiby R3 II have more play in the encoder and never caused any issues.
Dec 16, 2024 at 5:27 AM Post #2,573 of 3,183
I don't understand if the fiio control app (at moment) allow to configure bt11 only under android or allow to configure bt11 only under Ios.
Dear friend,
Hi, both iOS and Android version FIIO Control APP control support BT11. But the firmware update for BT11 is not supported in Android APP yet.
Best regards
Dec 16, 2024 at 5:29 AM Post #2,574 of 3,183
That 'play' is inherent to the design of this type of rotating push buttons. It's to make the press feel natural as typically you're not pushing it dead center with your thumb. Usually you're hitting it from an off center towards the top of the button. Especially if you have large thumbs. Nothing to worry about.
Dec 16, 2024 at 5:31 AM Post #2,575 of 3,183
@FiiO I would appreciate it if you could clarify this issue.I was thinking of getting this adapter too and just for this purpose.
Dear friend,
Hi, Aptx Lossless support in BT11 is having some issue still, we are still improving. If everything goes well, the new firmware for BT11 would be available this month.
You could connect BTR17 with other device via Aptx Lossless instead:
Best regards
Dec 16, 2024 at 12:59 PM Post #2,576 of 3,183
Received the BTR17 today and the experience is HORRIBLE!
Its such a mess that it will be even hard to describe the issue but will try.
So the Desktop mode (BTR17 connected to the external power bank) works only via BT.
When i connect the Fiio to the phone via USB to play lossless, the Desktop Mode (still having the BTR connected to the power bank) is bugged as hell. It boosts the volume but only up to 40 volume steps, then it completely stops changing loudness. The when switched to the High Gain, the volume doesnt go down so there is no difference between High Gain and Desktop Mode anymore.
The BTR17 recognizes the actual setting but the volume doesnt work anymore.
I even connected the BTR17 to a different charger and nothing.
Also tried playing through different apps (UAPP, Tidal, Qobuz) and NOTHING.
I did factory reset 2 times and it still didnt solve this weird issue.
May i ask WTH is going on?
Dec 16, 2024 at 1:12 PM Post #2,577 of 3,183
Idk, just tried mine on my phone Samsung 21 and desktop mode worked fine. I'll try a power bank later but this was with a Wal wart. I probably won't use it because on have meze 99 classics and iems. I set it to phone, maybe the powebank wasn't enough juice?
On another note the old sr21 can't select anything other than aptx. And my Sony won't change to anything other than LDAC. Even though it shows aptX and aptx Adaptive when I highlight the button it's still ldac. So probably will need bt 11 if I want to try the lossless aptx. Where you trying it on phone or pc?
Dec 16, 2024 at 1:16 PM Post #2,578 of 3,183
Ok i think i know whats going on. The Fiio app is bugged as hell, especially when it comes to the PEQ. Ive had the PEQ applied through the Fiio app and this messed with the volume/High gainand Desktop mode.
I switched the PEQ off and applied EQ through Wavelet and this fixed the issue.
@FiiO plz make your app usable for PEQ if possible, thank you
Dec 16, 2024 at 1:58 PM Post #2,580 of 3,183
Dumb question, did you upgrade the btr17 through fiio app? I've had no trouble with peq on any app or any gain or desktop mode. Works like a champ except sometimes you have to spam the save EQ button. Hopefully fiio can help, I don't have wavelet though, but if it's an EQ app wouldn't that double EQ things if you use fiio peq on top of it? If I forget to turn a system wide eq suite off it sounds terrible if I engage the fiio peq. And you by change didn't bump the master gain setting on the EQ up by accident?
Rudimentary I know, but sometimes I myself miss obvious stuff.
