Aevum
- May 15, 2007
im waiting for the local reseller (zococity) to have it, had warranty issues when ordering with aliexpress.
Mine insist in pausing the BTR17, annoying.Thanks, indeed, sometimes pockets are unpredictable in their willing.
10 user profiles to choose from. 10 filter bands for each profile. There’s a selection of peak filter, low shelf, and high shelf. max and min gain of [12dB, -12dB], q value range from 0.25 to 8. It’s pretty easy to select different user profiles on the Btr17 itself using the volume wheel.Any more details on the parametric EQ for the BTR17? I'm hoping I can finally replace my aging Qudelix 5k
Why? Cause you are missing the glass?Just received mine from a local shop after they got stock just last minute before I clicked buy on Aliexpress. I’m loving the design and the UI but perhaps not the build quality compared to BTR15.
I already posted this earlier. It’s available in Germany, both on Amazon and from the local official dealer NT Global, in case you don’t want to wait. Warranty is the same in EU.im waiting for the local reseller (zococity) to have it, had warranty issues when ordering with aliexpress.
Do you feel it lowers the SQ using the EQ? Because I had the impression with older Fiio offerings...I replaced my 5K with the BTR17. you can modify the PEQ both through the web (on USB) and the FiiO Control app. There’s a few user slots as well as out of the box curves. It’s clunky and slow to edit compared to the 5K, but seems to work.
BTR15 felt like a solid slab of glass and aluminium, similar to modern smartphones in terms of solidity. BTR17 has some hollowness to it, especially obvious if you tap on the textured backplate. The wheel and switches are slightly wobbly which adds to that feel.Why? Cause you are missing the glass?
Specs for 16/32/300 Ohm are published for 3.5/4.4 low/high/D-Mode on Fiio's website.Good morning, what's Fiio Btr17 Vrms output with desktop mode high gain?
