FiiO BTA10, Bluetooth Adapter/Amp for Audio-Technica ATH-M50X Headphones.
Discussion in 'Headphones (full-size)' started by demond, Nov 28, 2018.
3
  1. FiiO
    FiiO Kicks Off 2019 with the BTA10: Bluetooth Adapter for Audio-Technica ATH-M50x!
    [​IMG]
    The difference in sound quality between Bluetooth headphones and wired headphones has lessened over time. But a good pair of headphones will last for years if you take good care of them, so we see the market needs of turning the wired headphones into wireless.
    With the success of the BTR series Bluetooth amplifiers, FiiO has the confidence to meet the needs and now we bring to our customers with the BTA10--the Bluetooth Adapter for Audio-Technica ATH-M50x series.
    The BTA10 is a Bluetooth adapter specifically designed to make your Audio-Technica ATH-M50x go wireless, which features:
    * Audiophile-grade high performance amplifier TPA6132A2
    * Built-in Qualcomm QC3005 Bluetooth chip
    * Support for Bluetooth 5.0 and SBC/AAC/aptX/aptX LL audio codecs
    * Up to 10 meters Bluetooth distance
    * Built-in microphone backed by Qualcomm cVc noise cancellation technology
    * Specifically designed to match the curve and size of your ATH-M50x headphones
    * Built-in lithium ion battery for 8 hours battery life
    * Red and blue dual-color status indicator light
    * Three-button inline controls (volume +/-, power/pairing/playback)
    * Quality assured from a respected name
    Check out the detailed introduction of the BTA10 at: www.fiio.com/bta10
    Join the discussion on Head-Fi at: https://bit.ly/2ArvZ5p
    If you have a pair of Audio-Technica ATH-M50x and want to make them go wireless, go and check with our local sales agen at: www.fiio.com/wheretobuy for its availability or kindly buy it at our Aliexpress store if it's not available in your local market at: https://bit.ly/2RtZ9ul
    Best Regards
    FiiO Electronics Technology Co., Ltd.
    FiiO Stay updated on FiiO at their sponsor page on Head-Fi.
    https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official https://www.instagram.com/fiioofficial/ https://www.fiio.com http://fiio.udesk.cn/im_client/?web_plugin_id=24494&group_id=47899&language=en-us
  2. harpo1
    No LDAC or AptX HD? No thanks.
  3. FiiO
    The asking price for the BTA10 is just $39.99, anyway. And at this price, it already supports Bluetooth 5.0 and SBC/AAC/aptX/aptX LL audio codecs.
  4. scracy
    Just purchased BTA10 whilst currently on a trip to China. All I can say is this product is outstanding, sound quality does not suffer whilst using Aptx codec, unlike the bluetooth version of the MSR7 that I previously owned this produces decent volume levels. Overall I'm very happy will the sound quality of this product and would happily recommend BTA10 as an addition to M50X headphones. I have not heard the Bluetooth version of M50X however given the battery life of the Bluetooth version I suspect it would lack volume in the same way that the Bluetooth version of the MSR7 does which is a shame because the sound quality of MSR7 Bluetooth was really good.
  5. FiiO
    :gs1000smile:Thanks for the support. Enjoy it!
    Best regards
  6. etoilebiscuit
    Can I ask if it could be compatible with m40x?
  7. FiiO
    Dear friend,
    No. This product is designed for only the M50X.
    Best regards
  8. harpo1
    So you say the asking price is $39.99 yet you're selling it on Amazon for $49.99. Typical FiiO state one thing and delivery something totally different.
  9. FiiO
  10. jms74
    Why?
    I'm almost certain they are exactly the same size where your product fits, and the 2.5mm connection is the same.
  11. FiiO
    Dear friend,
    The depth and structure of the headphone plug are different. So BTA10 could not be compatible with other Audio-Technica headphones.
    Best regards
  12. jms74
    Have you tried ?
    Cause I use the cables from the m50x on the m40x without any problems whatsoever
  13. FiiO
    Dear friend,
    Yes. We could confirm that the M40X is not compatible with the BTA10.
    Best regards
  14. thetrev
    Can you confirm if LDAC or even AptX-HD will be added later in a firmware upgrade? Without any codec resembling the bitrate of basic lossless (600-900kbps), this will be a MASSIVE downgrade in quality and not worth swapping out my wire for.
  15. headitaly
3
