FiiO’s Upgraded Bluetooth Amplifier BTR1K: Qualcomm QCC 3005 BT chip, BT 5.0 and aptX /aptX LL/AAC supported, RGB light, NFC pairing, Type C and USB DAC
Discussion in 'Portable Headphone Amps' started by demond, May 23, 2017.
42 43 44 45 46 47 48 49 50 51
53
  1. akupaka
    Thx martadinata and Freemanix
    This helped! But I cannot get the output to work in Rhythmbox.
    What is interesting sound plays in Firefox. Moreover if I run Youtube in Firefox and start playback in Rhythmbox while Youtube plays I have output from both simultaneously, but as soon as I stop Youtube playback there is no sound from Rhythmbox again.
    Do you have any suggestions how to get it to work in every application? Thx!
  2. akupaka
    It's not about feelings it's more about ergonomics =)
    I use BTR1k as hands-free for my phone (I bought it just because of this possibility because I couldn't find appropriate bluetooth headphones with good mic and sound) and it's quite uncomfortable to search for that small button on the side to answer calls etc when it mounted to your shirt =)
    ps: and this button is also accidentally pushed when I carry BTR1k in my bag powering it on))
    sidecross likes this.
  3. sidecross
    I agree with you!
    I use two btr1k's for my on the street use and 1 btr3 for all night use. I wish the btr1k had a larger battery, if it did I would no longer want to use the btr3 for the reasons you describe.
    You might try a piece of tape loosely over the button; if this a major problem, I wish it was my big problem. :)
  4. akupaka
    It would be great although I don't use it too much, maybe 1-2 hours per day, while walking home. Maybe some very small power bank could help =)
  5. sidecross
    I am disabled and use my hearing for many hours at a time: I can leave the btr3 'on' for 10 hours at night without ever having to recharge. This make my night time listening in bed much easier.
  6. akupaka
    I use other devices while at home or office, which constantly connected to power source.
    But I don't actually use headphones while in bed, I think this is a bit dangerous and uncomfortable, because I use over ear headphones =)
    Isn't it possible to connect yours to some power source? Maybe some small as a AA battery power bank, there are some 3000 mAh.
  7. sidecross
    I use the fiio fa1 iem and there is no danger from the voltage and amps at this level, and if its perceived by some as a danger it is the least of my concerns.
  8. akupaka
    They look nice and tiny!
    Unfortunately for me I don't like this kind of headphones, I don't like that effect of a vacuum and hearing my thoughts))
  9. SirSith
    Hello,
    I have a problem with my BTR1K- problem with the microphone to be exact.
    Mic is seen as an audio input (headset's mic) under both WIN10 and Ubuntu (the newest vanilla, don't remember the number), yet no application can recieve audio from it. I've checked gain- 100%. I'v been talking to it and level bar doesn't move a bit.
    I can't hear anything with "listening" box checked. Same problem under Linux.
    Microphone is working and checked with phone, so it's not hardware problem, I suppose. So what then?
  10. FiiO
    Dear friend,
    When working as USB DAC, the microphone of BTR1K is disabled. Please try to reset the BTR by holding the volume +&- for 5s and check again?
    Best regards
    FiiO Stay updated on FiiO at their sponsor page on Head-Fi.
    https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official https://www.instagram.com/fiioofficial/ https://www.fiio.com http://fiio.udesk.cn/im_client/?web_plugin_id=24494&group_id=47899&language=en-us
  11. SirSith
    Why so? This is the exact function I want to use in that case. Does microphone work only while connected via BlueTooth?
  12. FiiO
    Dear friend,
    The computer will set the original microphone in itself for default input still. So when working as USB DAC, the microphone of BTR1K is disabled.
    Best regards
  13. robar
    Hi!
    Can the sampling rate be switched between 44.1 and 48khz on the Fiio BTR1K on windows? Or is it locked to one specific rate?
    By the way anybody used SMSL X4 from here? I have one and would be interested in an usb sound comparison between the X4 and bt1k / btr3
    thanks
  14. FiiO
    Dear friend,
    Yes, you could switch between 44.1 and 48kHz from sound-BTR1K-property:
    Best regards
    robar likes this.
  15. robar
    Thank you very much, I'm happy to hear that!
53
