FiiO’s Upgraded Bluetooth Amplifier BTR1K: Qualcomm QCC 3005 BT chip, BT 5.0 and aptX /aptX LL/AAC supported, RGB light, NFC pairing, Type C and USB DAC
Discussion in 'Portable Headphone Amps' started by demond, May 23, 2017.
41 42 43 44 45 46 47 48 49 50
52 53
  1. FiiO
    Dear friend,
    But the engineer also told me that Bluetooth 5.0 does not have improvement in battery consumption consumption.
    Best regards
    FiiO Stay updated on FiiO at their sponsor page on Head-Fi.
    https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official https://www.instagram.com/fiioofficial/ https://www.fiio.com http://fiio.udesk.cn/im_client/?web_plugin_id=24494&group_id=47899&language=en-us
  2. sidecross
    ‘With this new version of Bluetooth, the special interest group (SIG) that controls the spec has opted to simply call it “Bluetooth 5” with no decimal point, no “v,” and no “LE.” Yes, it still included the low energy protocol (and it has been greatly improved), but it’s all wrapped up into one simple brand: Bluetooth 5. The Bluetooth SIG wanted to make the branding simpler and easier for the public to understand.
    In order to take advantage of Bluetooth 5, you’ll need new Bluetooth 5 gear. If you have an iPhone 8/Plus, or iPhone X, you’ve already got the phone part taken care of. Apple was one of the first to ship a Bluetooth 5 compatible phone (along with Samsung in the Galaxy S8). ‘
    https://www.macworld.com/article/3262664/bluetooth-5-faq-everything-you-need-to-know.html
    ‘Its specification includes the low power consumption, inexpensive hardware and, small size implementations.’
    https://www.amarinfotech.com/differences-comparisons-bluetooth-5-vs-4-2.html
  3. gorman
    Anyone? I fail to understand how having a button you use once per "session" so bigger than the one you use much more often makes any kind of sense.
    akupaka likes this.
  4. sidecross
    I am not fond of the controls either, I find them worse on the btr3.
    The problem may be the difficulty to engineer controls on such a small size device.
  5. fiiobtr1
    Hi everybody.
    Has anyone else had the problem with the BTR1 V2.0 that it won't connect the handsfree profile on the phone but just the audio profile?
    I've had this problem for like 20 reboots of the BTR1 and with different phones...
  6. sidecross
    You might want to reset the device; you press down both plus and minus volume at the same time for a few seconds then retry to pair as if for the first time.
  7. thebrieze
    This or the BTR3? Assuming I do not need the additional codecs (Aptx HD, etc.) will there be any difference is sound quality? Are the Amp and DAC sections similar?
  8. sidecross
    https://www.fiio.com/btr1k_comparison
  9. Bombyx
    For Hi-Fi audio purposes, BT5 is not more power efficient than BT4.2, @FiiO is right about that. Do not trust web articles about BT5, most of them are inaccurate.
  10. sidecross
    Thank you, I will look at the links you provided.
    From my understanding all devices in bluetooth chain must be 5.0 compatible for lower battery consumption.
  11. sidecross
    I did read the link you provided but I would like to see other data that does not seem to insinuate a conspiracy to falsify the bluetooth upgrade.
    Also bluetooth 5 is a chip-set and not just a firmware update, btr3 is bluetooth 4.2 while btr1k is bluetooth 5 chip-set.
    So far your data is the only I have seen with this allegation of misinformation. Is this a redux Rashomon? :)
  12. Bombyx
    Huh? When there is misinformation about BT5, it is (of course) not intentional. Just journalists and bloggers extrapolating from partial information (e.g. press releases) and copying each other. The accurate and complete data is freely available on the Bluetooth SIG website (there and there). From those documents, it is clear that BT5 brings many improvements, but all of them are for the Bluetooth LE (Low Energy) mode, currently not used by Hi-Fi audio streams. The only improvement that applies to the Bluetooth Classic mode (used by Hi-Fi audio streams) is the SAM (Slot Availability Mask) which improves the coexistence with LTE devices.
    A quote from a good article by Gary Sims:
    • Bluetooth 5 extends and enhances the Bluetooth Low Energy aspects of Bluetooth, it does not alter Bluetooth Classic.
    • BLE is not used for streaming audio to wireless speakers. This means that any notions of increased range or speed for audio streaming over Bluetooth BDR/EDR are wrong.
    • Bluetooth 5 offers greater speed and distance for Bluetooth Low Energy connections but these are mutually exclusive, you either have greater speed or greater range, not both.
    Radsone ES100 (same chipset as BTR3) became compliant with BT5 via firmware update, several months after its release. This is because Qualcomm made several versions of the base firmware (upon which manufacturers can build their own). As for BTR1K, its chipset is more recent, compliant with BT5 from the start.
    sidecross likes this.
  13. sidecross
    You are implying that with this amount of disinformation available there is no way to know fact from conjecture. Is this web site and others like it a source of information pollution?
    I am glad that you have brought up this discrepancy and I do appreciate it as well as the links provided. Thank you.
  14. akupaka
    I second that! I would change those buttons behavior as soon as this is available!
  15. sidecross
    I feel for the larger button to verify which one it is; I do not find this a great problem to be solved. :)
    The btr1k does not have this problem; the btr3 does.
52 53
