FIDUE A83 impressions and discussion thread
post-10872400
Post #136 of 3,062
Waqar
Just got these 2 days ago, and the sound is amazing from these. But i have a problem with the left earpiece, that is when i move the cable a little the sound cuts out, this does not happened to the right earpiece. I even tried to disconnect and connect the cable but the sound still cuts out when the cable is moved.
I read that someone else also had some problems a few pages back. Well i guess i have too send them back for repairs.
post-10881102
Post #138 of 3,062
Waqar
Are the more people that have problems with these?
post-10881122
Post #140 of 3,062
Waqar
  Some IEMs with MMCX connectors are notorious for having connection failures(like Shure's SE iems). Try cleaning the connectors.
Ahh, yes the problem occurs when i move the wire close to the connector. Ill try too clean it. Thanks
post-10881131
Post #141 of 3,062
Waqar
It helped too clean it, but it did not fully solve the problem:frowning2:
post-10881664
Post #142 of 3,062
kimvictor
Yeah. It's a pain. Shure's IEMs always need a monthly cleaning, but cleaning it never solved the issue fully. New cable, washer rings for the connector(SE846's cable has it), or a deep cleaning(with cleaning agents) should fully solve the issue. Best of lucks.
post-10882754
Post #143 of 3,062
fxim
Just swapped the original cable for a 7N occ 8 wire 26 awg copper cable. Sounds much better.
I used a multimeter to the original wire and it came to about 0.9-0.8 range, the new cable came to 0.05 ohm reading.
The vocals and bass sound much better, the treble is a bit smoother but not as significant improvement with the new wire.
post-10885347
Post #144 of 3,062
Waqar
Hmm, i can send it back and get myself a replacement pair. But that replacement pair may also develop this problem someday cause of the Shure connectors. Then i am just gonna end up paying the shipment too China for nothing.
What would ou guys do? I am quiet puzzled here.
post-10885407
Post #145 of 3,062
H20Fidelity
I believe I have a pair of Fidue A83 coming in this week. I'll be sure to pop in sometime. I hold great confidence in Brooko's opinion on them.
post-10886220
Post #146 of 3,062
kimvictor
Well, there definitely is variation from pair to pair. My friend's SE215SP's connectors were good for 3 months, while my SE215 had connection issues after a month of usage. If the connection is really that bad, try to swap the left and right of the cable, and figure out if it is indeed the MMCX that's causing the problem. If it is, even a replacement cable should improve the issue by a lot.
And I have a pair coming in from Fidue as well! I'm trying not to read any reviews on them(so as to prevent any bias), but quite a few told me that they were great.
post-10886533
Post #147 of 3,062
I've been slack actually - photos are taken, review is half written - but I haven't had time to finish it yet.  What I will say is that out of the IEM's I've heard (including the DN-1000, Altone200, SE535 LE and quite a few others) - the A83 is the best I've heard - for my personal tastes.  I only had Vics one for two days before I bought (purchased) a set from Fidue.  More once I finish the review - but these are pretty close to Nirvana for me!
post-10886793
Post #148 of 3,062
Loquah
Melbourne, Australia
Website
passionforsound.lachlanfennen.com
I'll be interested to hear your thoughts. There's no doubt they're very transparent and coherent. I've fired them up again today for a session while I work and happened to try the Brainwavz S5 tips on the A83 - they're a great fit for me!
post-10892681
Post #149 of 3,062
H20Fidelity
So the Fidue A83 arrived to me this morning.
All I'm going to say is........
My Rhapsodio hybrid has met its match.
post-10892909
Post #150 of 3,062
Told ya
