Well, for that not, but you can blame me for my further advices:
At this point in time, when you will soon have an M-Scaler for your TT2 you definitely need some good dual BNC cables and 2 linear power supplies for both TT2 and M-Scaler.
Then you might be fine for a period of time, in which you can think about Dave.
PS. When you receive it, if you can, it would be interesting to try an M-Scaler + Hugo 2 vs M-Scaler + TT2. But for connection to Hugo 2 things are not as simple because I think you'll need an adapter from 2 x BNC -> Coax (?) to be able to link them?
Right-o OH, this time I
can blame you...at least for the LPSs! Contrary to Chord's opinions, and voiding the warranty if they damage the TT2 or m-scaler, my inexpensive LPS (but with much better replacement mains and DC cables) does indeed bring improvements over the stock SMPS power supply
. So now - again at my own risk - I am awaiting a second for the m-scaler, which should soon be off the production line, hopefully!
As for the "good" BNC cables, I'm glad to say that my shift from
tube experimenting to
cables is paying very handsome dividends indeed. And for any DIYers interested in such a venture, I shall give a brief(?!) summary of my findings re. an alternative to the conventional coax digital cable.
After my mk1 version, using cat 7 Ethernet cable's four individually foil shielded conduits as carriers for replacement Neotech teflon coated UP-OCC solid silver and copper wires, and which almost matched a £900+ Chord Indigo Tuned Aray cable, I copied their design of using
two separate cables - one for signal, and the other's (wire) conductors for return instead of the conventional use of a single's braid shield. (I personally have always questioned the efficacy of using such a mismatched return, especially in a cable using high quality signal wires lol!).
Anyway, being surprised at the results from my unorthodox use of cat7 cable instead of normal coax, I made such a dual cable using cannibalised cat
8 cables this time (their being of even higher spec, with better shielding still). And the results (for my TT2 at least) were way beyond expectations...surpassing in fact said Chord cable. And so, perhaps just an idea for those willing to have a go at trying such an animal...or if not, at least
dualing conventional coax cables, and
not using any braided shield as return!
NB. cat 8 cable is sturdier than cat 7, and it's much harder to extract the original twisted wire pairs, especially over about 35cm. Over that, cat 7 would be a better bet. And if UP-OCC
teflon coated silver runs too expensive, then at least
teflon coated OCC copper will still perform extremely well.
Also, in my system at least, the superior shielding has meant
no need for ferrite cores .
So, GOOD LUCK to any intrepid trailblazers...this time for
cables instead of
tubes lol!
ps. Will let you know if the second LPS for m-scaler is a waste of money or not (then I
would blame you, mon ami!!
)...CHEERS!...CJ
