OK guys.....................................
GOOD - No, GREAT news re. the reissue Genalex Gold Lion KT66.....................................
After a (very) bad day, it was rescued (once again!) by coming home to a package of our wondrous glass marvels - ie. a matched pair of these Electro-Harmonix reissue Genalex KT66s. And I'm happy, if not very pleasantly surprised after
@DecentLevi 's unfortunate experience to say that straight out of the box, and as a driver to a 7581A power, there's
no hint whatsoever of hum, clipping or distortion of any kind! Even with the vol knob at max, no music playing, or at unlistenable playing volume levels.
And what's even more surprising (and exciting!) is the fact that straight out of the box, it's sounding very good indeed lol
...far better than the new 7581A did as driver in the early days. Apparently these tubes from Hot Rox UK have had a certain amount of burn-in already, but nonetheless I'm sure it's nowhere near the full amount (150+ hours minimum IMHO) this tube family needs. So to sound this good already bodes extremely well for this reasonably priced tube. And going by my initial gut reaction after years of experimenting with 'unorthodox' tubes (and which is usually not too far off the mark, fortunately!), I suspect this KT66 could well eventually surpass the 7581A...truly, lol!
And as
@UntilThen says , the KT66 is indeed a beautiful tube...and this particular Russian (again) reissue looks as well constructed as I'm sure to be close to, if not as good as, the original...a thing of beauty indeed. It's also a very
large tube, as can be seen from the photos below. But more important, of course, is how it
sounds...and apart from stage needing to develop a bit more yet - which it will most certainly do with more hours on it - it's already a match for the reissue Tung Sol 7581A...amazing!
Plus, I have just popped one in the power slot - driven by its partner - and once again,
total silence where it should be, and still not the slightest hint of distortion or complaint from the amp. And this is with one of Mrsx's (first) adapters...which will be fine for burn-in, but will be replaced with one of my own ASAP lol!
And so DL, regarding your bad experience, I can only surmise that either your tubes are at fault, or your adapters...unless there's something very strange going on re. compatibility with some of your other gear...???? I myself can't see why there should be any difference between NOS tubes and these identically constructed reissues (although stranger things have happened lol!)...but I've no intention of paying silly money for the former, especially given how these particular copies are sounding already lol!
I just hope your own tubes prove to be OK in your next amp...CJ
ps...............PHOTOS......
pps. Can't wait to get a lot more hours on these beauties...
