Hi G,
If you have two different driver tubes that sound similar, nothing prevents you from using them as a pair. IMHO you can only hear a difference when they are very dissimilar or vary a lot in how loud they play. Sometimes two different tubes will complement each other and enhance the sound as well.
With separate voltage regulators you can run two tubes on different voltages as well. - not a problem.
The Elise certainly does look like it will be a great little amp. But since I am more of a tinkerer and tube roller than an audiophile, the fact that it requires two drivers is a non-starter for me. I have too many single drivers, some quite rare and often expensive, and the thought that I would have to try to find matches for these tubes in order to enjoy them stops me cold. But it is great to see the enthusiasm here, and I sincerely hope it lives up to everyone's expectations.
Hi gibosi.
Pity then us poor things with the LD MKIII/IV/SE!
Hi G,
I certainly agree with you, m - I found a mix of PsVane CV181-TII and a 7N7 much better than 2 of each. Mind you, these were as powers, but I suppose the same could be true used as drivers...
