FEARLESS Audio IEM's Discussion/Impressions
Oct 16, 2021 at 11:02 AM Post #5,176 of 5,189
Redcarmoose
Fearless are getting back in the game with a bunch of affordable hybrids. They look... interesting - Shangri-la especially, could be a detail freak.
PRODUCT SPECIFICATIONS​
Sensitivity
112dB (@1kHz)
Impedance
22Ω (@1kHz)
Frequency response range
15Hz-20000Hz
Passive noise reduction
26dB
Drives
Fearless special research pole magnetic dynamic driver
Sonion 23 colorful world cooperation funds Medium and High Frequency BA *2
Colorful World 2nd generation ultra high frequency BA*2
https://www.linsoul.com/products/fearless-shangri-la
I saw those earlier, exciting!
Oct 16, 2021 at 1:07 PM Post #5,177 of 5,189
illumidata
Capricorn
Oct 21, 2021 at 9:27 PM Post #5,178 of 5,189
JIMMY CHILE
CHILE
Sensitivity
112dB (@1kHz)
Impedance
22Ω (@1kHz)
15Hz-20000Hz
26dB
Drives
Do you think any of these will improve what was done with S8F? or will it be another tequila?
I would like to see you return to the game FEARLESS.
Dec 9, 2021 at 6:35 PM Post #5,181 of 5,189
mungster
SF east bay
Dec 14, 2021 at 6:48 AM Post #5,182 of 5,189
bachankas
I am a happy owner of Fearless S8F since about a month. Fantastic IEMs, very fast and nice technical approach, love it in a metal music.
However I found that the stock tips make then sound a bit harsh. I found that tips with wider inner diameter like the FLC8 tips provide better balance between highs and upper midrange.
Which other tips can you recommend?
Anyway, fantastic IEMs for fast and heavy music.
Dec 24, 2021 at 11:48 PM Post #5,183 of 5,189
courierdriver
Canada
Your post made me realize that I haven't listened to my S8P's for a few months It’s a shame because I really like how they sound but the size and the long stem makes them uncomfortable for me to use on a regular basis. If you want to tame some treble harshness with tips; I rec a set of Newbee memory foam tips. They are available on both Amazon and Aliexpress and can be ordered in 6 pair packages. I use these tips on all my iems to enhance bass and take the edge off the upper mids and treble regions. Get the red version though; because the black have a reputation of breaking apart and not being as soft. Just my 2 cents.
Dec 25, 2021 at 3:37 PM Post #5,184 of 5,189
Eddie C
Calgary, AB Canada
Your post made me realize i havent listened to my S8P in about 1.5 months haha im always using my Sundaras hooked up to my desktop. Sundaras are good for crystal clearness, but the warmth and isolation from the S8P makes me love them equally if not a tad bit more than the Sundara.
Jan 19, 2022 at 2:37 AM Post #5,185 of 5,189
bachankas
I have another question.
I really like the S8F sound. However, the bass is very shy with low amount. I did not hear what most of the frequency response shown.
I sent my pair for FR measurements and the graph confirmed what I hear.
Did the sound change with some revision change? Did anyone meet similar S8F sound?
Jan 19, 2022 at 4:18 AM Post #5,186 of 5,189
Precogvision
Reviewer at Headphones.com
California
That’s not how it should graph - the Fearless S8 series is pretty bassy. That’s also a major roll-off; it looks like your unit has dead BAs in the bass or there was a leak somewhere when it was measured.
Jan 19, 2022 at 4:51 AM Post #5,187 of 5,189
bachankas
If that would be case in one IEM, I woudl consider that there is some failure, but this bass rolloff is present on both earphones.
