Wow..
BLUF: Definitely the worst unboxing experience / initial impression for me, EVER!
First, what kind of $1K IEM doesn't even come in its own case? I was appalled to witness how it shipped in a S10 Genie case/cover/ with S10 description and tech spec. And the packaging is dismal for this price range. It comes w/ 4x pairs of silicone tips and 1x pair of foam tips all shoved into the carrying case along with the earpieces and the cable.
What a ****ty product launch. There should be no excuse for the amount of money they're asking for.
At least the carrying case looks decent.
And then the cable.... Not sure where to even begin. This is the worst cable to accompany a $1K IEM. As soon as its plugged in, the left side cuts in and out with crazy static and volume fluctuation with every twist. I know several folks warned about this, but to be honest, I just brushed it off thinking 'It can't be that bad.' Well folks, I hereby confirm......it is that bad.
And the initial sound impression. PLS take it with a pinch of salt, as I've only kept them in my ears for less than 10 min. With that being said, I'm pretty sure I have a defective unit. It just doesn't sound right. And within the first few seconds of auditioning, I noticed the L/channel cutout, and immediately switched the cable with a PW audio cable. Noticed huge improvement, but they still didn't sound right. I could still hear a faint static and crackle sound with every note on the left side, even after switching out the cable. And I noticed a significant L/R channel imbalance. Overall, it sounded very veiled and hollow with lots of echo?? for some reason. With bit of exaggeration, it almost sounded like someone singing on a karaoke machine or listening to music in the bathroom. To be honest, I've had $50 IEMs that sounded better. And then the low frequency sounded very muddy. Maybe I've gotten used to the TE5B, which have superb quality/control in the low frequencies. Overall, can't say it was a pleasant experience for me. I understand there's been a huge hype and lots of praise from respectable reviewers to include BGGAR, whose opinion I highly value, but this set just wasn't for me. For me, this is the end of the road for high end Chi-fi. From here on out, i'm staying far away from boutique companies and chi-fi (unless they're <$100 set), and sticking to big companies, reputable brand, and high-end Japanese brand.
The pros: Fit. Probably the second best fitting IEMs (for me) after the Shure SE846. And the earpiece is gorgeous. Very good finish. That's about all I can say.
To switch gears, I remember someone earlier asked for a size comparison between Roland and TE5B. Well, here it is.
It's not a huge difference in size. Roland is tad thicker. The upside is Roland is far more comfortable than the TE5B for my ears. Good insertion depth with decent isolation.
