kingpage
- Apr 26, 2010
Do you have a E7? Because I don't think E7's volume can be controlled from the computer (Windows 7), if it can, my unit must be faulty.
Do you have E7? Because I don't think E7's volume can be controlled from the computer (Windows 7), if it can, my unit must be faulty.
The E7's bass boost doesn't disort anything unless you have a faulty unit of some settings on your pc arent right, i listern to dubstep which has some big low bass lines even with bass boost on 3 theres no disortion , even with badly mastered stuff thats mastered to be loud.
I run windows 7 and use winamp , winamp & windows volume set to max and i control the volume with the volume control on the e7, no software effects no upsampling or anything, drivers are default windows 7 drivers, and no disortion.
The E7's amp stage can be over-driven when the bass boost is turned on. When used with the EMU 0404 USB, for example, the extra hot line out signal from the EMU will cause the E7 to distort on bass levels 2 and 3. Level 1 is just fine, exactly as described in the first post of this tread.
In cases like this, reduce the source output level until the distortion goes away and then decrease by another 3dB or so for good measure.
Jack
Also try another music files, because I can't believe a hardware problem would go away by decreasing the volume on the computer from 100% to 75%. I think it's either your computer or the music files. A hardware issue would still persist with any setting software-wise. How many headphones have you tried? Do the distortion occur in all headphones?
Not saying it's impossible, but it is quite unlikely that you can solve a hardware problem by simply reducing the volume at the source while maintaining the same listening level by increasing the volume on E7 at the same time. The problem is solved by manipulating the volume levels is what surprises me.
Maybe getting a replacement is the best bet for you since having the same problem twice is as unlikely as winning a lotto. But what you want is to make sure it's really E7 at fault here.
HOWEVER, JRG1990 claims that he is able to max out volume on his software/computer, control the volume on the E7, and utilized ALL bass boost levels w/o running into any distortion!
I would like to add another thing that hasn't really been discussed but I mentioned this in my very first post. When I connect my Sony DAP via Aux In, the there is no distortion at all 3 levels. I tested it again just now with my Sony at max volume AND with my custom EQ that has the low freqs already boosted quite a bit. Again, zero distortion.
