FA7, the first Quad drivers IEM from FiiO , all Knowles BAs and 3D printed technical , MMCX design
post-14705225
Post #211 of 667
Marco Angel
Mexico
Mexico
I wish the FH7 will be having dual high, dual mid, and 13mm DD. Mmmm..... 13mm DD is wonderful.
@FiiO
Guess this could be a good configuration:
the FH5 is a great sounding iem, at least to my ears, i would let the sub-bass-mids as they are and just even the mids-highs (and don't attempt to replicate the FA7 elevated mids)
post-14705295
Post #212 of 667
Llermo
Barcelona
Barcelona
Age
43
post-14705305
Post #213 of 667
Sorry - haven’t heard anything from Ibasso. They’ve never approached me, and I don’t solicit review samples.
Reactions: Redcarmoose
post-14705808
Post #215 of 667
jaxz
Which bands mid bass are? I will try to eq.
post-14707046
Post #216 of 667
Fawzay
Red Dot
Red Dot
post-14707502
Post #217 of 667
FactoryStock
Neitherherenorthere
Neitherherenorthere
Gave them a try today, and the treble portion is very familiar. Like a...not painful version of F9 Pro.
Isolation and fit, awesome. FLUSH in my ear. Noice! Stock cable is annoying, but fixable with 3rd party. And there's zero hiss. Nada, squat.
Vocals are not bad, too.
Bass portion a little too warm, but I slightly like it. Doesn't kick too hard, but preferred to be a bit more 'relaxed' or lower volume, and rolled off a bit. Would be good to strip off and transfer all that warmth to mids and vocals-lower treble. Only slightly warm mids; everything else need to be close to reference.
Still I have to continue hunting. It also needs a little more "outside my head" sorcery for piano, violin, piccolo and harp.
post-14707522
Post #218 of 667
domho7
Hi I have the fh5 how does it compare w the fa7 tks
post-14707525
Post #219 of 667
mhoopes
Campbell, CA
Campbell, CA
Could you tell us what recording(s) you evaluated the FA7 with that had the aforementioned instrumentation? I'm curious to hear it, myself.
post-14707627
Post #221 of 667
sidecross
North America
North America
post-14707638
Post #222 of 667
mhoopes
Campbell, CA
Campbell, CA
Any comparisons for comfort compared to the FH5? Debating between the 2.
I have both, and I'd say there's not a big difference in comfort. The FH5 inserts shallower, but the nozzles are about 0.75 mm larger in diameter. The FH5's S.TURBO spiral transmission line creates an interference with my inferior crus, and there was some minor discomfort there when I tried to get enough insertion depth to achieve a decent seal with silicone tips. I added some spacers at the nozzle base, which helped the insertion depth issue, and eliminated the interference. The wider nozzle also means that comfort with foam tips is somewhat compromised; there's less give available. That said, once dialed in, the FH5 is extremely comfortable.
The FA7 inserts deeper (about average for the IEMs I've tried), due to better ergonomics near the nozzle base, and has narrower nozzles. Retention is better, so I'm not fiddling with them quite as much.
I'd say the differences in resolution and voicing are much larger factors in my preferences. Once EQ'd, the FA7 has the advantage in resolution and mid-bass attack (more "reference"), and a bit wider soundstage. The FH5 has more sub-bass capability, and more of those bass harmonic distortion components that lend some extra texture and perceived quantity - you know, the DD thing. Bass guitars sound fantastic on the FH5.
I'm keeping both.
Reactions: sidecross
post-14707659
Post #223 of 667
nzhoward
New York
New York
I'm keeping both.
Which would you say is more similar to the Shure SE846 (if you have experience with it)
post-14707688
Post #224 of 667
mhoopes
Campbell, CA
Campbell, CA
Sorry, I don't have any experience up the price scale in IEMs. @Brooko has reviewed both recently, though he didn't compare the two in his FA7 review.
post-14707697
Post #225 of 667
sidecross
North America
North America
"...How they did it is, in the world of IEMs, extremely daring, innovative. They created a patent pending acoustic low-pass filter. The output from the dual bass drivers that make up each of the SE846 earpiece's "subwoofer" is run through a high acoustic mass pathway carved into ten precision-welded stainless steel plates. That channel, if unfurled, would be approximately four inches long, and allows the low-frequency roll-off to happen acoustically. The result is deep, impactful bass, with remarkable midrange presence and clarity...."
https://www.head-fi.org/articles/head-fi-buying-guide-in-ear-headphones-2.17591/
The question might be like 'comparing oranges to apples'. :)
