Extension cable for Senn. HD650
Jul 20, 2010 at 2:33 AM Thread Starter Post #1 of 3
usf09
Right now my headphones almost reach to my bed, but an additional 2-3 feet of cable would be awesome as I would rather use my HD650 than my DBA-02 at home. Is there a good, relatively cheap headphone extension cord I can buy that won't degrade the SQ? I was considering recabling the headphones, but I think that will just be too expensive. I'd like an option under ~$50 if possible...thanks for any info!
Jul 21, 2010 at 1:24 AM Post #2 of 3
kingtz
Grado extension cable...
http://www.amazon.com/Grado-Extension-Cable-4-57m-Headphone/dp/B0006DPNNK/ref=pd_sim_e_1
Jul 21, 2010 at 2:31 PM Post #3 of 3
usf09
Thanks for the suggestion, in the end I ended up picking up one from eBay...It uses Mogami 2534 wire and Neutrik connectors, so it's a pretty solid/cheap cable. Hopefully it won't color the sound at all, but for $36 it's a great deal on a cable with solid components. I was going to go with the Dimarzio Silver for $65 but I decided to try something a little cheaper first...
