michaelhwolff
Member of the Trade: Michael Wolff Cables
- May 23, 2004
Power conditioners may or may not be beneficial to you system. I would say that the majority of them are. So lets talk about the importance of the power cord that comes from the power conditioner to you CD player.
You have gone to the expense of adding a power conditioner to filter, regenerate, and make your power as clean as you can get it. Then after that expense you put the stock cord back in place which has a crucial effect on the power that has just been cleaned or conditioned.
Back to the water analogy. You use reverse osmosis and carbon to condition the water as it comes out of the tap. Then for some unkown reason you drink from a cup that has coffee stains in the bottom which was used for breakfast. Hmmmm. You just negated the reason for having all the filtration.
Does this help to understand that the power conditioner is just part of the link. I would say that any power cord used prior to the power conditioner would be where you might be able to use the standard cord.
But then you have to be a believer.
Regards,
Michael
Regards,
Michael
