Thank you, Fkelly5, taoster and ai0tron for your replies and comments.
The fact is that I don't use LAME, which I understand it's a compression tool. I don't want to obtain mp3s, I just want to make perfect 1:1 copies from audio CDs.
I used to use Nero and/or Easy CD Creator, but, suddenly, I noticed that a CDR made with Nero had some clicks and pops. Horror!
OK, then, I said to myself, if it's like that... I will use EAC from now on. I heard it's the best of the best of the best, Sir!
Actually it seems it is, but, unfortunatly, my burner (Yamaha CRW8824) is not able to burn with EAC (or EAC is not able to burn with my Yamaha writer).
So I extract tracks from the CD with EAC, save them on my hard disk in .wav format, then I close EAC, open Easy CD Creator or Nero and compile the CDR with the .wav files from the hard disk.
Everything seems now OK, the resulting CDR plays fine on a CDplayer, but, if I try to extract the tracks from it again with EAC, it gives errors ("sync error").
This makes me believe that in fact the CDR is not perfect, but that it has imperfections which are more or less corrected by the CDplayer during playback.
Or is it just because EAC extraction is unforgiving and reveals imperfections which were not revealed by the other softwares?
Anyway, here I am, transformed from a happy listener of CDRs burned with Nero into some freak paying less attention to th music and more to identifying possible clicks or hisses
Sorry for the long story.
As a conclusion: should I keep using EAC for extraction and Nero or Easy CD Creator for writing, or is there a better solution to obtain PERFECT COPIES from audio CDs???
Thanks again, folks!
