burningyen
- Mar 4, 2010
I'm a long-time Shure E2c user who just got a new pair of HF5's a couple of days ago. I loved the sound of the E2c's enough not only to replace the plug when it started shorting out, but to keep repairing the replacement plug when that too started to go. But after a couple of years of this I finally got fed up with the constant repairs and got the HF5's. I like the sound of the HF5's well enough. They have crisper treble and recessed mids relative to the E2c's. It's hard for me to say which is the more accurate sounding, not having a high quality reference system to compare them against. The HF5 cable is super microphonic, but the included shirt clip works well to tame that. I really wish it were longer, though. It's too short for me to use at my desk at work. The seal with the big tri-flanges is excellent; it's so good that I worry that if the earbuds were to be accidentally yanked out they might suck my eardrums out with them. But despite the excellent seal, the isolation is only fair. The E2c's are much better in this regard, but I can compromise.
So, onto the problem: when I'm walking outdoors with the HF5's, even the slightest breeze creates a whistling noise in my ears. And where I live, on the water here in NYC, there is a constant strong wind, which means the whistle turns into a loud wail. When I cup my hands around my ears the whistling stops. Has anyone else had this problem? I'm going to try using the foam tips and see if that helps. But long term I'm hoping for some other solution, because I hate foam tips. Having to squeeze them and wait for them to settle in my ears drives me nuts, plus they seem like the least sanitary type of tip. For some reason mine didn't come with glider tips, even though I bought the HF5's new from a retailer.
Any suggestions?
Any suggestions?
