orfeo
- Dec 15, 2005
Hi,
I recently got the jack on my er6 replaced since both channels were dropping out due to the wires at the jack end being damages (i expect from pressure and repeated bending). So now that i have a new jack on the the end both channels work but i am getting a harsh clipping sound when i turn the volume up (to a quite high level , say 5-7mm below max on a 3rg gen ipod). The clipping sound is a very high pitched scratchy pop and crackly sound, which is very loud, above the level of the music. This is something that i'm almost certain that i didn't have before.
I talked about this in the headphone forum and someone said i need to replace the filters which is what i plan to do. But since it cost me $25 to get the new jack and it would cost another $25 for the filters (and tool) it makes the bill close to the $69+postage fee the Etymotic charge for a brand new pair of ER-6's. Hense i want to be sure that getting new filters will do the trick.
I should also mention that i've noticed that the right channel is alot softer than the left channel, say at about 75% the volume of the left. But i think this problem has been around before the repair.
So i was wondering if there might be another cause for the problems i'm having? I thought some one who is maybe a bit more tech savey might be able to help. Is there any chance that the repair of the jack could result in these problems? The materials not matching the the etymotic standars? The jack the guy gave me was a straight plug coated in gold (or something like it), you unscrew the jack to reveal the wires solderd to the jack with the ground going to the cord and the cord clamped down in the jack plug (i think this is a pretty standard plug but i thought i should give as much info as possible).
If anyone can shed any light on this i'd love to hear your thoughts
thanks
orfeo
thanks
orfeo
