Etymotic 6i - Filter changing how often required?
post-1493330
Thread Starter
Post #1 of 13
beta3
Hi
I'm a new 6i user (from Sony's EX71) and i like them (but i miss the bass a bit)
But the reason for this thread is that i'm flying on vacation for 3 weeks next month.
Do I need to take the replacement filters with me?
Questions put general: How often is filter changing required?
post-1493350
Post #2 of 13
warpdriver
If your ears are pretty clean, they may easily last 6-12 months.
post-1493424
Post #3 of 13
labrat
Deleted.
post-1493428
Post #4 of 13
beta3
Originally Posted by labrat
I have had my ETY4P's for nearly 2 years now, did a change of filters 6 months ago just to check if it made any difference; It did not.
Now 2 months ago, returning from a trip to Asia; Very hot and damp there!
I noticed a level-difference between the channels when I came home, checked and saw the left filter had turned from green to yellow, and replaced both filters.
The yellow filter was smoldering when touched, obviously the dampness had gotten to it!
So my answer is: If the filters (or tube wherein the filter is situated) is not exposed to dirt, wax or moisture, they will last possibly forever!
and i'm about to fly to Guangzhou, HongKong and Shanghai
how did you treat yours in Asia?
post-1493436
Post #5 of 13
labrat
Deleted.
post-1493837
Post #6 of 13
drarthurwells
I clean my ears with Q tips at least every few days, but try to do this everytime before inserting my Etymotics.
Also, I take a small jeweler's screwdriver and insert in the tube that goes into the driver, and clean the tube out. It is wax that goes inside this tube that clogs the filter.
I only change a filter when I lose the sound in one channel.
post-1493861
Post #7 of 13
labrat
Deleted.
post-1493889
Post #8 of 13
darkninja67
I have not changed mine since I got them around 4 months ago. Keep your ears clean and you will be fine. I use Murine for wax removal chores.
post-1494209
Post #9 of 13
JeffS
I've had mine for almost a year, and I changed them after about 6 months.
I also try to keep my ears very clean and use the stuff you can get from
your local pharmacy. (Dont use Q-Tips)
Even with good aural hygine, you'll still want to change them regularly, but
you should get at least 6 months out of a pair unless you have a lot of wax
issues. Also, keep them away from moisture. It will kill the filters.
When they're wet, it will pretty much block all sound. After they dry out it
will sound "normal" Once you change them to new filters, you'll realized that
they weren't good after getting wet.
good luck
-Jeff
post-1993352
Post #10 of 13
ky77
How much is the replacement filter for ER4P?
post-1993414
Post #11 of 13
darkninja67
3 pairs for $15 at www.headphone.com Kind of pricey but not too bad if you change them every 6-12 months or so. I think they can be found cheaper too.
post-1993522
Post #12 of 13
EscaBoi
6 filters or 3 pairs for $12 at ideal Sound on ebay here.
just ordered some filters from them myself for my ER6i's, great people to deal with.
post-1994833
Post #13 of 13
ky77
Thanks for your reply.
