MattTCG
- Jan 22, 2012
Not that anyone would even ask, but the pad change add 4 grams total the curb weight of the e2. So 294 grams.
I'm getting better at swapping the pads now. It helps if you take the bottom seam and center it to the connector just below it. Then smoosh the pad flat against the table or your hand. Don't forget the seal is critical.
