hemtmaker
- May 25, 2013
@dan, once the new pads are available, would you encourage the dealers to install them on the demo pair, so that we can try them out?
Not to my ears with my cans. And I hear the difference quite clearly. Both using Vivo cable. Using the angled pads on my EFO.Interesting. Based on my brief listening on both cans using the stock pads. I found the EFO brighter than E2
Let me double check with the dealer and give them another listen. It’s always good to validate what our ears can hear cheers!Not to my ears with my cans. And I hear the difference quite clearly. Both using Vivo cable. Using the angled pads on my EFO.
Have your EFOs been upgraded to 1.1? Which inserts are you using? Cable differences?
Got the sample pads in and here are some quick impressions after an hour:
It’s nice to have choices, for a multitude of reasons. Mrspeakers now offers a choice of both suede and perforated pads to go along with the stock leather pads. These pads are designed to offer a signature that complements the stock pads. So for those of you who are looking for something a little different with ETHER 2 house sound and don’t care for EQ, you now have choices.
The perforated pads will bend the signature towards neutral with more of a “reference” sound. There is still a good dash of warmth from the original pad signature, but these will offer a new level of transparency. If you like fine detail, subtlety and sonic nuance, then this may be the pad for you. Sound stage is the best with these, pushing well off the shoulder for width and digs out depth cues very well creating a spacious musical platform.
The suede pads take a somewhat different approach. I’ll cautiously refer to these as the “basshead” pads (evil grin). Sub bass sounds punched up around 3 db or so (just a rough guess). But don’t be mistaken here, nothing in the signature is out of place. There is still a seamless transition from bass to mids with no bleed whatsoever. But damn, the bass really hits hard with these pads! There is a more intimate presentation of vocals and stage here.
While both perforated and suede feel softer than stock, the suede is the softest. Because the suede is the softest pad, it should offer less clamp for those who feel that clamp with the stock pad is too much.
So now there are three pad options with each offering a different flavor and are each compelling in their own way. It’s difficult to say which is my favorite. It’s in the early going but I have to say I’m drawn to the sound and comfort of the suede pads.
Thanks for the impressions. There's clearly a perforated set in my future.Got the sample pads in and here are some quick impressions after an hour:
Really looking forward to the pad options (especially the suede).
How do the pads get stored when they are not on the headphone? Some kind of wax paper, like the back of stickers or bandaid adhesive?
Curious if you have and/or tried the Estat pads on the E2s?
Keith
Can you comment on the mechanics of swapping the pads, and also how you switch back to the stock pads?
I have the e-stat pads for my EFO. I wonder if you could put them (or any EFO style pads) on the E2s. I assume the E2 pads are flat on the underside, while the EFO pads have the 'flaps' used to attach them. Seems like it might be hard to make the elastomer ring work on them.Really looking forward to the pad options (especially the suede).
Keith
Thanks for the initial impressions: most helpful.Got the sample pads in and here are some quick impressions after an hour:
