Spyro
- Apr 15, 2003
That's a tough call. It really depends on your budget. I owned ER6i's, ER4P's (twice) and the S-cable. The lack of weight and oomph with the presentation, and terrible microphonics always had me eventually selling them off. HF5 fixes one of those two problems (better ergonomics/better cable). The UM3X is my serious rock out intense listening IEM. I could never see parting with them. I had been using TFPro10's for working out and while they do work fine with complys, they still have a pretty big profile and are a bit cumbersome. But they sound excellent. I just figured the HF5 is a much better alternative for working out. The bass still extends deep. It just lacks weight. It's really the only real negative aspect of the Ety (IMHO).
Etys definitely lacks the weight of UM3X but that pristine clean sound was so nice to listen to once again. I would prefer to answer your question by saying if I only had $200 or less to spend on one IEM, it would definitely be an Ety. I'd live with "lighter" bass with everything else it does so well.
UM3X is warmer and weightier than Ety but still very cleanly detailed. A great product! They are similar in that they are both very balanced and neutral and smallish soundstages, exceptional instrument separation but the UM3X is heavier and a bit warmer sounding (in a very good way!).
Originally Posted by ibis99 /img/forum/go_quote.gif Hi Spyro, since the price difference between the UM3x ans ER4s is about $200 would you consider the ER4s close enough to the UM and save $200 |
