Cthulhu
- Jan 8, 2005
What this has to do with anything.
The proposed replay gain standard clearly indicates that it works by inserting metadata into files (APEv2 tags) and they are used by devices to determine the correct loudness at which to playback the file.
Why would using FLAC or any of the numerous other formats supported by the replay gain spec make a difference here? now the specific program MP3Gain has some other (funky) options, but that is not the discussion at hand.
No, because replaygain does it's magic when decoding FLAC -> PCM
Thats what i was trying to say in the first instance. The other digital attentuation methods here work after the file has been decoded, the replaygain metadata tags merely give additional infomation how to generate the PCM waveform (by changing the position of the waveform relative to 0, so the average volume is 89 DB instead of 98,for example)
going along with the general spirit of this thread, wont lowering the volume digitally via software, which is essentially what replaygain does for me, lead to loss of bits? |
