Empire Ears - Discussion & Impressions (Formerly EarWerkz)
post-12766795
Post #2,281 of 22,926
Docterror
  It’s been a while since I received these little fellas (still a very happy chappy with the way they look):
A little bit of hacking on the inside of the custom case has made a great protector for the RWAK380 when travelling :xf_eek:)
So now it’s about time to give a bit of feedback regarding my journey with the Empire Ears Zeus R.
I am no review expert and never will claim to be but here is my experience explained in the best terms I can try to muster together.
When I first received the Zeus R I had an initial listen using the RWAK380 + RWAK380AMP combo.
This was using the balanced output from the amp and the Norne audio cable. Initial feeling was that the sound felt closed in and not so clear compared to the Noble K10U I use to run with the same system. One thing that did stand out though was the vocals they already sounded clean and natural.
So I left the cable and IEMs running for 100 or so hours and went back to it. Burn in is one of those things that some people believe in it and others don’t…. I am in the believe camp but that is mainly due to the speaker based solution I use to have in the past.
After 50 hours I had another little listen to the system and found that the sound had started to open up, the bass was more present and the highs cleaner. So I left it running for another 50 or maybe even more  hours to see what happens.
Work trip came along and I thought heck yeah I can take along my new toy :xf_eek:) After using the RWAK380+RWAKAMP combo for the period of the trip I realised the sound was great but there was a lot of noise/hiss due to the amp having too much power for the Zeus R.
Since I never used the RWAK380 balanced output I plugged the IEMs in and left them running for many hours to put some run in time on that output.
Hiss gone and music sounding as sweet as when I used the 380+Amp combo I decided to put the time and effort into listening to this as the solution to travel with in the future.
The Zeus-R came with comply tips and spin fit tips. I had some extra comply tips left over in the size I used with the Nobles and which worked well for me so I took them as a starting point to listen with. For some time I used this combination and what I discovered was that at times the Zeus-R sounded absolutely amazing and at other times then the sound was muddled and unclear.
For example Pete Townshend's Classic Quadrophenia some days would sound stunning each instrument from the orchestra clearly defined and then other days a muddled up mess.
So back to the drawing board and at this point it had to be linked to the seal I was getting using the ear tips so I decided to play around with the different tips supplied….. turns out that the spin fit tips sound the best with a size small in one ear and medium in the other. I tried using the same small and medium combination with the comply tips as well but without a doubt the spin fit tips provide better bass and highs.
One thing I am starting to get use to is using silicon tips and also pushing the IEMs what feels very deep into my ears which feels a bit uncomfortable  since my ears are use to being pampered with Comply soft memory foam tips for several years now.
So now after many hours of experimenting I finally had a solution that sounds good every time I put the Zeus R into my ears.
RWAK380 (balanced output)
Norne Therium 8 wire balanced cable
EE Zeus R
Spin fit ear tips.
The Zeus R reminds me a bit of the wilson benesch speakers I use to have in the past they were transparent speakers that revealed exactly what the rest of your equipment sounds like changing the source / amplifier or even cables would changes the way the speakers sounded and the Zeus R is exactly the same.
On to how this setup sounds with the system mentioned above:
First of all there is literally no audible hiss when using the RWAK380 balanced output which was a problem when using the RWAK380+RWAKAMP combination.
Music wise has been a mixture of every genre in both 16bit and 24bit formats…. the joys of all songs and shuffle :)
One thing that still amazes me is the soundstage on these IEMs, this is something that is usually found in the full size headphone domain so to get this sensation in a portable solution is an amazing thing to have.
Vocals are still the one thing when using the Zeus R that stands out, it doesn’t matter if it’s a male or female vocalist or even if it’s a backup singer the clarity, natural sound and spacing is the best I have ever heard from an in ear monitor.
Staging of the instruments in the sound space allows you to pin point every instrument present in the music. When one of the songs from Red Hot Chilli Peppers first album turned up on the random playback I heard a trumpet being played to the left side which I have never noticed before and I thought I was familiar with this album
Regarding the highs and bass this part was highly critical of the seal you managed to get in your ears as mentioned above using the wrong tip and size affected all aspects of the music which in the past I have found a bit more forgiving in some of the other manufacturers UIEMs.
Once you get the fit right then the highs are crystal clear and the bass is deep and clean.
If you are a bass head and like your eyeballs shaking in their sockets then these may not be the IEMs for you. If you want natural well balanced bass that does not dominate the music unless the musician or band intended the bass to be the key point of the track then these deliver this sensation in spades.
As mentioned above I am no review expert so this is more of a summary of my time with the Zeus R, am I happy with the system that I am running while out on the road….. absolutely to have such a compact solution that sounds near as damn it as good as my home system is something I have been searching for a long time and now I have found it….. well at least for now
What did I learn from this little journey, if you are running UIEMs play around with the tips because the sound difference can be night and day.
I am still trying to get use to how deep the spin fit have to be inserted and the comfort of them compared to the foam tips but as soon as the music starts playing it’s well worth the minor discomfort which is not as bad as it was initially any more.
Should I have gone for CIEMs, probably yes and hopefully EE can change these into a CIEM in the future for me but I couldn’t find a good place to get ear impressions in Zürich so I went with the UIEM option with no regrets because it will probably help me get use to the depth a CIEM will have to go in my ear.
All in all a very happy user of the Zeus R :)
Put this in the Reviews Section. Easier to find in the future than scroll through all the whole thread.
Reactions: flinkenick
post-12766841
Post #2,282 of 22,926
ejong7
Kuala Lumpur, Malaysia
A very good question, but I can't think of anything right now from my IEMs (maybe some resemblance to DN2000J, though those could get harsh)..  I might have to compare with some of my full size, maybe EL8C or T5p 2nd gen.  How about you, anything you can compare it to?  Maurice already mentioned KSE1500
It's not entirely similar, but I do find the reasons of me loving my R and my Ether the same: Its neutral without being boring, reference yet musical. And the Ether (non-Flow) shares the same property as R that I found, it has wide soundstage, but definitely not the widest I've heard, even in the line. Ether C is wider for Mr.Speakers, Apollo is wider for EE.
In terms of IEMs, well....... I may have an answer but probably not the time to say it.
post-12767235
Post #2,283 of 22,926
ejong7
Got my 'hard' clamshell case today. It fit my Zeus R very well. My R is particularly big (at least compared to the universal) so I was very happy it fits with room to spare. If anybody is interested I'm posting the link for the UK people here:
https://www.amazon.co.uk/gp/product/B01AED3H70/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Nothing bad about the hard case or soft pouch Empire provided, I just prefer to store my IEMs in zip cases for easy transport.
post-12767297
Post #2,284 of 22,926
Cagin
Belgium
Belgium
I'm baffled.
I dunno what happened or when, but did Empire Ears ninja out of CanJam London?!?
I had at first wondered how come there weren't taking part in the SHaG prizelist, I figured a Spartan/Cerberus maybe
Then today I just watched Jude's classic pre-CanJam vid, and was dumbfounded to not see any sequence about Empire, and then not even in the list at the end.
I then went to check the CanJam Exhibitor list and no Empire Ears there either. I could've sworn it used to be there but maybe I was just seeing a mirage previously.
Just did a search within this thread, with "London" after another search with "CanJam London" and there's no mention of backing out of it. Page #103 shows Jack enthusiastic about it, followed few pages later by Eu Jin's London gif.
And as far as I know there's no European Empire Ears dealer yet so does this mean there's no Empire Ears iems line-up for demo at CanJam?
I'm aware I wasn't actively posting lately. My review about the Zeus-R should be up by Friday or Sunday at max.
I'm truly bummed about CanJam though. I'd waited a lot to hear out the other iems in the line-up, and I wanted to spend a good 30min more with the Zeus to A/B with my Zeus-R.
I got one idea what could be a cause but I'm afraid even watered down, I'd risk a ban and I rather not, especially as I'm on the volunteering staff... -_-
post-12767306
Post #2,285 of 22,926
ejong7
  I'm baffled.
le.mao. wise thoughts my friend.
post-12767712
Post #2,286 of 22,926
EagleWings
India
India
They usually do Black Fridays, but well its a year to year thing. One can hope though
Thanks. How about during CANJAMs?
post-12767824
Post #2,288 of 22,926
Sound Eq
post-12767827
Post #2,289 of 22,926
Deezel177
Reviewer at The Headphone List
Jakarta, Indonesia
Jakarta, Indonesia
Website
www.TheHeadphoneList.com
so is it a cable or an iem ?
The Arthur itself is a universal IEM with 14 drivers and Effect Audio internal wiring. The default cable that comes with it is the silver-gold Effect Audio Excalibur.
post-12767831
Post #2,290 of 22,926
Sound Eq
so do you think this is the exiting news Jack was talking about?
post-12767841
Post #2,291 of 22,926
esm87
maybe I should hold off the zeus until this comes out and read reviews!
post-12767852
Post #2,292 of 22,926
ibbreezy
Too many to keep up with.
Hope they offer the cables to existing EE users. Along with a discount naturally.
post-12767863
Post #2,293 of 22,926
Kozato
Singapore
Singapore
The Excaliber cable will be exclusive to the Arthur only, same for the Rowan cable and the Merlin IEM.
Reactions: ibbreezy
post-12767942
Post #2,294 of 22,926
Deezel177
Jakarta, Indonesia
Jakarta, Indonesia
Website
Users Who Are Viewing This Thread (Users: 26, Guests: 26)
