KuroKitsu
I would assume that most folks would be using the XIV tuning on the XR and basing my response on that. Being the owner of an R, Im not sure the 2 wire would translate.you are not paying attention , so let me repeat
the 2-wire is the one that pairs well with XR , 4-wire is too bright
btw i have a 150$ copper cable on my XR - as i feel that spending 1000$ on a cable shows either abundance of wealth or abundance of insanity - and i am happy with it
but if i inherited a rich uncle or something tomorrow, well yeah 1960s 2w would be my next buy (and wm1z and maybe phantom)
cheers
I did try finding a 2 wire to demo while I was in Hong Kong, but nothing doing.
Oh wow...that is....quite appealing.In term of quality, it is one of the best, their 2 pins cant come off, and the only way to take it off is cut it, and the plug is furutech, cant get any better than that
My consideration of Horus was that I heard it worked well across a lot of IEMs. Considering that I most likely wont be stopping at Zeus, I wanted something that could do that. Do you feel that the 2 wire does the same?
