warrior1975
- Dec 5, 2013
@notorious4163 well, maybe I lowered your expectations and you will be pleasantly surprised and be even happier when I'm wrong?
astell and kern sp1000 best amp out there
or best budget friendly
imicro dsd bl
imicro dsd bl
imicro dsd bl
I think AMP8 for the DX200 might be a good challenger in terms of one of the best AMPs out there(6,2V RMS with +/- 8V voltage swing and a whopping 2700mA of current which is the key spec for a low impedance IEM like the Phantom), I’ll get a chance to have a comparative listen with SP1000 in two weeks I have been yearning to try out SP1000 with Phantom...
Even before comparing, I can vouch for AMP8 being a great pairing for the Phantom
Can you help me understand this mw power thing i dont know much about. And man 2700mw at what ohm range? That sounds outragiously high!
My hdv 820 can do 956m956mw at 300ohm but not 2700my goodness
hey unfortunately, my legend x says it’s been delivered (10:30am) it’s 2 pm now and usps says it’s been delivered to the front desk (i live in a big condo in nyc) so there might be a chance my package is missing.
inb4 senpuku if usps lost my legend x’s i swear to God, ill go full Oldboy on USPS
Edit: i understand when they say delivered it might not actually mean it and it’s just in the trucks or en route BUT USPS DONT TELL ME ITS HERE AND MAKE ME MANIC
For real? That's terrible, sorry to hear that bro. Maybe someone at front desk has it. It should be signature required ,so hopefully that helps track it.
GUYS I GOT IT!!! So after listening to for 30 min, first impressions...
barely stronger bass than the atlas, i could even say the atlas is more fun to listen than the legend x but i truly appreciate the improved clarity and resolution
you were right not going to lie slightly disappointed. can anyone recommend a good cable for legend x or is stock the best option?
Edit: fit is great not amazing though, i can see why people want customs. QUESTION is blue left side and red right? doesn’t say anything about L and R on just the Moniters
The effect audio logo should be facing out (away from sound tube). The L and R on the inside of the 2pin cable connector should face in.Edit: how do you put the cable in? does it matter which way u stick the 2 pins in
What are you kidding me, I been wearing red on left and blue on rightRed is right, blue is left. You have to wear them with cable over the ear. They don’t work cable down like you can do with the atlas.
