Canadian411
- Jan 24, 2011
Ya, I might order Pelican PB2 also and compare side by side with sr71b.
And then maybe the DAC to enhance a bit.
SR-71B is designed to drive all HD600-800 with outmost ease with great quality of sound reproduction using balanced output.
With those phones, you have to use a better source than iPod or any portable Digital player. Also you have to make sure your music is in lossless.
SR-71B was developed using $25,000.00 Bolder CD player as a source.
Ray Samuels
really? i felt the sound stage of the HD800 were compressed through the SR71B from a gamma2 dac. yea its not a 25000$ system, but its not an ipod. clarity was there though.
Cheers for the input. I agree with you completely.
However it gets back to the portable thing. If I spend $600 on the solo and more than that again on an amp - add in a source - and the question starts to arise 1) do I want to be hauling around $2000+ in audio equipment, and 2) at what point does it stop being portable? This is obviously extremely subjective.
For my purposes I draw the line at a good amp and a decent source. I don't have the best amp in the world, and I don't have the best source, but I also almost never have the best environment for listening to top quality music. For my situation the PB2 provides the best cost/performance solution. I'll likely soon be grabbing a DB2 as well to give more flexibility with my sources.
I really wish Apple would make it easier to bypass their DAC, as they have done their amps. Don't know why they are so hung up on preventing it. I am looking around for a different/better portable source, I just haven't decided on which one to try next (Cowon, Hifiman, Next-Flavour-of-the-Month).
yea portability is a big issue fo rme with the solo. plus i dont use an ipod anymore.
others may disagree, but i find the cowon j3 + sr71b + jh16 to be very, very good. after setting up my BBE eq, im starting to feel like i prefer the jh16 +sr71b over anything else if heard. i havent heard a ton, but i have heard most of the flagships and down.
portability wise, i rather have the j3 and a pico slim or arrow though. to me, carrying around a 3 or 4 box rig i guess counts as portable, just not ideal.
Thanks Jalo, I also read a lot about sr71b being slightly better than iBasso PB2, that was the reason I purchase sr71b.
So looks like I am on the right route here. haha.
Any recommendation on cables ? from solo to sr71b ?, anyone makes balanced end input plug for sr71b ?
You are right, nothing beats the Pico Slim for portability. My ultra set up: Nano 6 + Pico Slim + JH13, try to beat thatTons of fun with ounces of weight.
On the other hand, there are times when I get stuck in a 15 hours transpacific flight and I just want to disappear into my world, nothing can beat the ipod/Solo/DB1/SR71b or PB2 into my ED8. The environment is really bad on an airplane and that is exactly the reason that I need a desktop like environment to immerse.
But to be fair, you have an kick ass set up also, hope you are doing it balance.
yes balanced out but since its single ended in, im not really taking full advantage of it
Hi Ray,
Didn't know you are following this site regularly.
Anyways, looks like my problem is then the source, I am using iphone 4/ipod with ALO LOD 18awg cables, once I get back my sr71b from you, I will try with different source device to see the differences.
Thanks,
D.
Pudu, if you want to try other DAPs and do not want to spend on the Solo, it is easy, just pick up any dap so long it has a digital out and you'll be fine especially if you are going to get the DB2. Once you can get the lossless 1s and 0s out of your dap and into the DB2, you'll be up in the high audiophile level.
