Eleven Audio XIAUDIO Formula S Headphone Amplifier
Nov 23, 2021 at 8:48 AM Post #421 of 544
WafflesID
United States
What you need to do is have music on pause and try the amp at full volume.
That's what I'm doing. I'm not hearing anything coming out of my 1266 at full volume. Currently have an su-9 plugged in via xlr. With a mini PC (a MeLE fanless) feeding the su-9 via USB.
Dec 3, 2021 at 8:59 PM Post #422 of 544
eskamobob1
anyone know what pinout the Sagra uses for i2s? I know its not the same as holo (tried that already), but other than that I'm lost
Dec 3, 2021 at 10:04 PM Post #423 of 544
cangle
Massachusetts
This is the pinout of the sagra. What are you trying to connect it to?
Dec 4, 2021 at 12:14 AM Post #424 of 544
eskamobob1
Dec 4, 2021 at 6:28 AM Post #425 of 544
cangle
Massachusetts
I'm trying to hook it to a su-2 KTE
Using the switches on the bottom of the SU-2 I would try the following:
1 on
2 off
3 off
4 off
5 off
6 test both but start with off
7 test both but start with off
8 off
9 on
10 on
Abyss sent me a different view of the Sagra pin out which is a bit more helpful for figuring out the i2s configurations of attached ddcs:
Then using the SU-2 switches instructions you should be able to get the switch settings I listed above. These are the instructions I'm referring to, from Shenzen Audio:
Dec 6, 2021 at 4:50 PM Post #426 of 544
eskamobob1
1 on
2 off
3 off
4 off
5 off
8 off
9 on
10 on
I massively appreciate the help. I didn't get a chance to try it this weekend but I should have plenty of time to try it tonight. Ill report back.
Slightly unrelated. I seem to recall that the sagra outputs an SE signal over the bal output. can anyone confirm that?
Dec 6, 2021 at 10:37 PM Post #427 of 544
eskamobob1
1 on
2 off
3 off
4 off
5 off
8 off
9 on
10 on
This worked! I dont have any dsd on hand to text but thats not the point of r2r anyways. Tyvm!
Dec 24, 2021 at 2:21 PM Post #429 of 544
DJJEZ
UK
Anyone compare the 4 pin xlr vs the 3 pin xlr out of the Formula S with the 1266?
It's identical as the formula S is not a truly balanced amp
Jan 14, 2022 at 12:01 PM Post #430 of 544
ajreynol
Hey guys, I hear a very soft buzz when I move windows around on my PC or am displaying a mostly white screen, audible through the headphones when no sound is playing. It can be heard through USB or optical when connected to a different source. Very clearly some sort of interference, but unsure how to resolve.
Is this a matter of plugging the Formula S into a different wall outlet or something else?
Also, the light on the formula S turning red with the audio stopping is the unit clipping, right? Was playing a challenging test track at about 7pm on the dial and it was cutting in and out. I don't have a manual and want to make sure that's not unusual.
Jan 14, 2022 at 1:08 PM Post #431 of 544
FLTWS
Eastern PA
I think that may be a problem, my F/S does not include a clipping indicator. I'd contact Abyss.
Jan 14, 2022 at 2:22 PM Post #432 of 544
ajreynol
Will do tyvm
Jan 14, 2022 at 6:53 PM Post #433 of 544
jlbrach
the red light is a solid red at all times and has been since I first bought it so sounds like something is amiss in your case
Jan 14, 2022 at 11:37 PM Post #434 of 544
Slim1970
STL
Yours is red? I have a white light on my Formula S. I also have a white light on my Powerman.
Jan 14, 2022 at 11:45 PM Post #435 of 544
DJJEZ
UK
Yours is red? I have a white light on mine Formula S. I also have a white light on my Powerman.
Me too..both white. Slightly purple at an angle
