@circlecrystal, if you want to copy and paste information from the internet at least do it in a form that is relevant to the two products under discussion. Your response clearly indicate that your knowledge about electronics is very limited, I would suggest looking at some DIY and other electronics pages to sharpen up your understanding of the subject before trying to comment on amplifier technicalities and topology. There is so much misinformation contained in your post that I'm not even sure where to start... Unfortunately it detracts a lot from the thread in being able to gather solid and good data about the Watson.
First of all, I do aprreciate you providing those suggestions. As I'm just a head-fi hobbiest like others here, which means I'm no where as nearly informed as experts in electronics, I quite agree you said that "I should sharpen my knowledge". So surely something I said can be wrong or mistakes.
But even from the point of a hobbiest, I would say I cannot quite agree with some points you mentioned before, such as "amp architecture doesn't affect sound much".
The sound difference between different amp classes is something not only I said, as I was repeatedly told it is true by different people and from different places.
And the comparions between class a and a/b is from https://www.thegearpage.net/board/index.php?threads/what-are-benefits-of-class-a-amps.390631/, where people discussed about the difference between class a and class a/b, which I quite agree with. As I feel they did make some points in the discussion, especially in terms of "does amp architecture make difference in sound", I chose to put them there. So it's merely just an answer to something you mentioned before as
...but amplification architecture seldom has as much to do with the sound compared to the implementation thereof
Surely if you feel different, you are very welcome to give your own opinions here. But please don't just say something like "there is so many mistakes that you don't even know where to start". As it won't be any helpful to the topic being discussed here.
Nevertheless, I'm actually still quite wondering why would you say Ember will likely run much cooler than Watson at the very first place, without even comparing them yourself.
In addition the Ember will likely run much cooler than the Class A Watson which may a plus or a minus for some.
I went to one of my local store and borrowed one Ember II amp, and listened to it for several minutes. To me Ember II sounds less 3-D than Watson on HD800, HE400i to my ear. However the under very low volume, Ember II does feel more balanced in left/right channel. Further impression inputs requires extended listening, which I didn't have enough time to so so far.
But as I noticed, the tube temperature of Watson is no where hotter than Ember II. Actually Ember II is slightly hotter to my hands. And the heat sink of Watson does feel quite warm, which I think only means these heat sinks are working well to reduce the tube temperature of Watson.
Lastly, as I said before, Watson has a very large tube family of EF95 for tube rolling. And I also shared the link for the startup tube rolling guide, to help people not knowing the topic understanding what EF95 tubes they can go for. That's why I cannot quite agree with what you said before, as
The Project Ember also has a huge advantage being able to roll a significant variety of valves and accommodating various adapters, vs the limited selection with the Watson.
EF95 is apparently a large family, so calling it "the limited selection with the Watson" is unfair, right?
As you keep saying "there is so much misinformation" here or there, then asking me to "sharpen up my knowledge" without giving details, and even though all those you said were distracting from the topics, you still called me out for derailing from the topic, when I tried to tell you the sound difference between different architectures.
As you mentioned before, you have owned Ember amp but not Watson yet, so I can understand your defending for Ember. However I would also like to ask you to be objective when saying something that will cause confusion, such as those I mentioned above.
Let's keep those comparison as objective as possible, and also try to focus on the very topics we are discussing.
The topics are:
1) How does Watson sound to our ears, when compared with Ember II?
2) Design-wise, what's the merites/cons of Watson's Class A to Ember's Class A/B that we know?
UPDATED:
And I have already given my answers to the topic questions in posts above actually:
1) I went to one of my local store and borrowed one Ember II amp, and listened to it for several minutes. To me Ember II sounds less 3-D than Watson on HD800, HE400i to my ear. However the under very low volume, Ember II does feel more balanced in left/right channel. Further impression inputs requires extended listening, which I didn't have enough time to so so far.
2) I was told by some different people and from some different places, Class A amps, when compared with other types of amps, have darker background, which can improve a lot to instruments separation, soundstage, deeper bass and tremble smoothness.
As you also mentioned adding external power supply above, and even saying Ember II can easily find one while Watson cannot...
1) I cannot hear noticeable difference by switching Watson's Switching PSU to a customized linear PSU (28v).
2) I cannot hear noticeable difference by adding AC filter to the chain.
That's to say, I don't think upgrading the power supply is neccessary, for Watson. But this may not hold true for Ember II, as I very much understand the difference between different amps.
