Originally Posted by GeekGirl
michaelconnor- thanks for your support and understanding of the problem (perhaps we have crossed paths in the AVS forum Philly HDTV thread?). RF thrives on the fundamental properties of electromagnetic waves. PCB substrate material and trace widths are part of the equation. At audio frequencies, these effects are neglible- a difference of 50 mils in the trace width isn't important whereas at RF frequencies (> 1 GHz or so) it's a disaster.
I'm happy with the responses to this thread. Hopefully it's an incentive for those who help the beginners to remember to add a few pointers about ESD.
I too work in RF (currently working on a broadband PA that tops out at 2 GHz), and it's been a real education. In the GHz range, everything matters, and making measurements can be very trying.
I've worked on digital stuff as well, and ESD is a pretty big deal there. I have seen flash memory chips fried through mishandling. On the manufacturing side, ESD is a huge issue, and since we are an ISO 9000 company, we have to comply with industry standards - that means anti-static flooring, mats on the benches, etc. Wrist/heel straps must be checked daily and logged for compliance. We've recently added devices to benches that automatically monitor and verify the continunity of your wrist strap. It's harder to enforce this attitude in Engineering, though
A company I worked for years ago produced a video on the effects of ESD on electronic components, not just killing them, but changing device characteristics. They basically took a part (I think it was a MOSFET, but I don't recall for sure now). They measured the device on a curve tracer, and zapped it with various levels of ESD and remeasured it after each zap. They also demonstrated how different packaging protects (or doesn't protect) sensitive parts.
I'm a bit of an ESD nag, since I'm the guy who usually has to troubleshoot and repair the stuff that gets fried.
Software guys are especially bad IMO, and I've had to lay down the law regarding handling of PWB's and wrist strap usage. And I do have a wrist strap at home, and use it when I have to get inside my PC.
The best way is to develop good work habits and use ESD precautions, whether it's a wrist strap or just being careful to ground yourself before handling sensitive devices.
