Effect Audio cables thread
Tags:
257 258 259 260 261 262 263 264 265 266
268 269 270 271 272 273 274
  1. Paul Zhang
    @mvvRAZ I would say when both of this cables are brought together, it'll synergise perfectly, imagine the incredible projection of details by the Leonidas II , paired up with natural, silky smooth projection of the Cleopatra. The sound It's gonna project will be an entirely new experience. :metal:
    Effect Audio Stay updated on Effect Audio at their sponsor page on Head-Fi.
    https://www.facebook.com/effectaudiosg/ https://twitter.com/EffectAudio https://www.instagram.com/effectaudio/ http://www.effectaudio.com/ info@effectaudio.com
    mvvRAZ likes this.
  2. mvvRAZ
    Follow up question
    Do you guys underdeclare value when shipping to EU
  3. Paul Zhang
    Of course, We can declare it according to your preference:wink: drop me a PM if you're interested in those cables!
  4. mvvRAZ
    Dropped! :)
    Paul Zhang likes this.
  5. mvvRAZ
    Woop woop order for the Bespoke Leo/Cleo has been placed! Can’t wait
    Layman1 and Paul Zhang like this.
  6. Paul Zhang
    @mvvRAZ Thank you for your support! It's gotta be good!
  7. mvvRAZ
    I’ve been divided between the Cleo Octa and the Leo Octa for so long now getting a mix of the two is beyond optimal haha
    Thanks!
  8. Vitor Valeri
    Vogue cables received! Review coming soon! Already I say that I noticed considerable improvements in the comfort, lightness and ergonomics of the cables and their connectors (compared to the Premium series).
  9. Paul Zhang
    @Vitor Valeri Bro Finally!! i believe It's gonna be worth the wait! Can't wait for your review!:metal::metal:
  10. hemtmaker
    Hi Paul,
    I demoed and bought an EROS ii 2pin-2.5mm cable from an authorised dealer in Sydney today. However, when I plugged the 2.5mm connector into my sp1000m, the left channel volume is a lot lower than the right unless I gently turned the plug a bit. It seems that turning it anti-clockwise works better. Do you think there is a tolerance issue with the plug? My other 2 balance cables do not have any issue (one from HeadphoneLounge and one from MeeAudio) Thx
    Regards,
    Andrew
  11. Paul Zhang
    Hi Andrew, I am so sorry to hear about that, It's most likely the connectors issues. Drop me a Pm Bro, I'll assist you with this. Cheers!
  12. hemtmaker
    Will do. Thanks!
  13. Markus Tappeser
    Hi all,
    I'm using my Leonidas now for about 2,5 years and I like to share my impression.
    First I need to say that I decided to buy this cable because I got a big help from Eric Chong and what can I say, the Leonidas did tweak the sound how he described, they match my understanding of how music need to sound (thanks for it).
    The improvement regarding the sound is outstanding. It was always an enjoyment to listen music, until several weeks ago. The cables got between the connector and the splitter more and more stiff.
    They began to get uncomfortable around the ears and can be heard with every movement.
    If the decision to buy a new cable is based only on the sound, Effect Audio for ever.
    But, sorry, the lack of the cables are so hard after such a short time and not to forget the cables are actually not cheap, makes them a no go.
    I hope effect audio will find a plastic which keep soft, at least for quite longer. Until then, I'm out.
    Enjoy the music
    Markus
  14. mvvRAZ
    I can’t imagine there’s a cable insulation that can go for 2.5 years and not stiffen tbh
  15. Paul Zhang
    Hi Markus, I am sorry to that the insulation are causing you such inconveniences, But would you mind dropping me a PM showing me some pictures of the insulation?
