Thankfully, things start going faster (or at least the feeling that you're accomplishing something) after the TO-92 transistors. The first of the large parts, the tube sockets are next. With a tube amp, it's important to have the standoffs very, very close to the tube sockets. Or, better yet - directly under each tube socket. This is because the act of plugging a tube into a socket puts a lot of stress on the socket and the PCB. If it's not properly supported, bad things can happen.
Once again, Doug spec'd an improvement in tube sockets:
https://s3.amazonaws.com/tubedepot-...ached_files/00004280-VT9-ST-C1.pdf?1383248764
The Belton socket has a couple of advantages as a PCB-pin tube socket:
- Fiberglass construction
- Low profile
With #1, you get high-temperature structural stability, along with vibration resistance. You don't get any vibration resistance with a typical ceramic socket. Old NOS sockets made out of bakelite are not exactly vibration-resistant.
With vibration resistance, you minimize microphonics. Every tube is probably microphonic to some degree, simply from the mechanical construction involved. So even if it's not audible, it might be measurable and have an otherwise non-localized affect on the sound quality that could be audible.
With #2, every instance I've measured and tested where the lead lengths were increased on tubes, either from socket protectors, flying leads, or what-have-you, the longer signal path causes measurable increases in noise. So, low profile is good from that perspective.
From the perspective of using standoffs, low profile is bad. It means the standoff mounting screws below are
captured by the tube sockets. IOW, if you don't put the screws in first - before soldering the tube sockets in place - you're in a world of hurt. I won't tell you what I went through with the first few T4s when I forgot this.
So with those screws highlighted above, here's a shot of the standoffs underneath the PCB:
And with the soldering done:
Top view of the sockets, along with the Molex plug-ins for the power transformer, the power inductor, and film filter caps also installed:
As you can see, there is a center hole in the sockets, so one is always able to tighten, loosen and remove the standoff. However, the screw stays secure under the socket, trapped by the socket pins.
Because the sockets undergo so much stress, I am careful to ensure that solder flows up the pin legs from the pads below. This ensures maximum strength with the socket's attachment to the PCB.
