illquid
- Mar 3, 2011
They are identical to the ones I got with my V1 that I ordered in April.
Hi Warlax,
Do you have the Sm3 v1 or v2? If the latter, you should have the new wide bored ones. Im pretty they all came with that. The v1s only came with the older, smaller opening tips.
I think v1 ordered in May come with the new tips. They were with mine but I bought used, so I'm not absolutely positive about this. I also ordered extras. Someone should just post a picture of them showing the sound hole. It will be evening before I can.
Sorry, I have the V1s. Though based on the pictures posted by Google (and linked by shane, thanks!) I believe I have the wider-bore tips, even though the tips there seem to be of a lighter color the bore size on the tips look the same. Unless the difference in bore size is hard to tell from pictures I'm quite sure I have the new ones, thanks!
Not sure if anyone can help but as a SM3 v1 owner last year, although I loved the sound I couldn't get a good fit with any tips including the Grey double, shure triple, comply's, olives, shure flexible or klipsch ovals, so relutantly had to sell them, and reverted back to westone as they fit me fine. Has the new shape helped with any previous fitting issues?
I realise that only people with experience of both would be able to help, but I'm considering getting the v2 if this issue had been resolved. It was discussed briefly in one of the previous appreciation threads for the v1, but from memory not many others had experienced this. I was never sure if it was due to the square shape of v1 or something like the angle of the nozzle.
Sorry for rambling, but any views would be appreciated. Cheers
As a previous westone 3 owner and now a SM3 v1 owner they do have a very slight difference's in the angle of the nozzle .
I can't help with the SM3 v2 fit .
But it's worth noting ,if you can't get any of the supplied tips to fit .Try experimenting with your own ear-tip designs .There is no practical reason to prevent you finding a good seal with a little trial and error.
For example, with the Westone 3's ,I could feel that whilst using the largest supplied Grey Silicon tips they just did not go deep enough into my ear canals . So I Glued the Silicon Grey Ear tips onto some 'extension' silicon tubes that I cut off some of the other tips that were supplied. And Got a perfect fit .
With the SM3's I had a different issue . Using the largest Grey silicon tip the SM3's v1 fitted my left ear perfectly but the right tip just wouldn't get that tight fit . I could feel that the Right bud needed to be a little Bigger .So I cut the tube off a Grey silicon ear peace and stretched the Bud over another Grey silicon tip making it bigger .And Got a perfect fit.
Moral of the story? .If at first you don't succeed ,adapt .
Feel why the IEM does not fit you and adapt the Supplied tips until you find the right shape or buy tips that you think will be that right shaped.
Just got the new Earsonics biflanges (wide-bored) in the mail today and have been using them with my Sm3 v1s for the past couple of hours. So far i can say I like them way better than the previous stock biflanges. The V1s signature seems more balanced now and the highs have a little more presence and clarity to them than before. Timbre seems the same, but will need to listen more to confirm this. They don't sound as warm as before (not by much) but still maintain all the traits I love about the v1s.
Physically, they seem softer and more comfortable than the previous stock tips, either because softer silicon is being used or perhaps because the bores are larger, making the stalks less thick, hence less stiff. Size-wise they're the same and I'm still getting the same level of seal / isolation, which is good.
Heretic Probably mentioned already but I can;t seem to find it (Comment was for the Thread Police) Where are you ordering these new ES Biflanges Thanks
Wow, that seems like a helluva lot of work to get an IEM to fit. LOL. Thankfully, the stock tips worked fine for me from the get-go. I don't think I would have had the patience to try quite so many permutations of tips.
ib you like the sm3 better than the W3? Could you explain a bit? Thanks and Thanks to all
I have that same picture without flash, just natural light
Dude ! the SM3 tip adaptation Took all of 5 minutes ,Max.
1.Cut Tube off unused large silicon Grey tip . (Though I was lucky enough to have some spare large Grey silicon tips ) You can buy them in packs .
2. Make the hole at the end of the Grey Silicon tips slightly Bigger using small scissors or knife
3. Stretch the remainder of the silicon Grey tip over another large tip ( it stays securely in place ) and hey presto . Xtra Large Grey Silicon Tip
4. Enjoy the Music
There it is again! A reference to a large ES silicon tip. Can you explain? I thought there is only one size for the ES tips. I'm referring to the tip size, not the bore. And where did you get them from in packs? ES' website sells them individually. I'd love to get a whole as backups...and to fool around with modding like you've explained.
Thanks in advance.
f
