May I ask who you are referring to please? I'd like to get an upgrade cable for my ES3sAwesome! I also have a few of his line-up! Great guy to deal with and SQ improvement punches well over his asking price.
Earsonics ES3
- Thread starter sly_in_the_sky
Can anyone recommend an upgrade cables + tips please?
I'm now using Final Audio E tips. I like how comfortable they are. Was previously using MandarinEs but found them to be uncomfortable during long listening.
He's a local DIYer. He doesn't ship internationally.
Freefallr4545
- Apr 30, 2011
D
Is it really that bad? They don’t look poor in pictures.
voidedsoul
- Jan 31, 2017
Hey guys, I am new into iems. I prefer open back cans and own a few like the 7xx, X2, magnums. I also like slightly bright signature. I have the opportunity to go for the es3 or the isine 10. Which will be a good option?
WhiskeyJacks
Well, first let me say that everything I have used from Earsonics has been above average or decent for my preferences. This IEM in particular I have not gotten to use due to the price increase a while back and having to budget. I know though if open back is what you prefer then the iSine 10 is already a point in due to it's design. I also have read extensively on both of those particular IEM/earphones and the iSine10(though seriously hyped) delivers very big sound for a small earphone and delivers more than many of the more conventional IEMs can due to it's differences both driver and open back. Albeit it also loses out on other that is the caveat, such as: Isolation, portability(as in easy to conceal and use without losing out sound quality due to work environment, transportation, busy streets, etc.), size, etc. Portability and isolation is two big reason's everyone is not walking around with full-size and open back headphones on their head at work or during a commute. So, it really comes down to you purpose with the in ear's you are going to use. In my experience if you are going to be using these mostly like transportable IEM's( as in from room to room through your apartment or house, or in quieter and more private settings) I would go with the iSine 10 or even the LX which runs cheaper and apparently is very close to sonic qualities as the 10. I know their will be things you will trade off between the iSine IEM models or the Earsonics ES3 model but the point is you just need to know what you want them for and it becomes much easier to make the choice. Sorry for the long rant but I have experienced this myself and felt that hopefully answering these reasons and purposes of use would help you decide on what best suits your needs. Let me know what you go with when you do chose and how you like them.
Rollk2
If you like IEM with a slightly bright sound signature, I'm not sure you'll love the ES3. They've a great sense of rythm and a nice transparency, but the trebles are not particularly sparkling despite a good extension.
voidedsoul
- Jan 31, 2017
Thanks for your detailed views on both the isine and es3. I want an iem for my outdoor use during commute so the isine is bad as per your suggestion. Will go with the es3 for the advantage of closed sound.
voidedsoul
- Jan 31, 2017
I don't prefer excessively bright sound or as some say harsh, but the FR of the es3 had good upper midrange and decent roll off. Had a listen to them and the cymbals were good sounding for me and had great extension as you said. Though sub bass was a bit more adding some warmth, was not an issue for me.
Just got the ES3 today. They sound delicious, a lot of details and some notes that I discover. Some guitar parts have some resonnance that I Don't hear before (it is my first expensive IEM).
A little minus, they are not as much confortable than my Nuforce EDC3.
A quick question, how much time do I have to use/burn them so they can have the best sounding ? thanks
- Jan 30, 2011
You don’t need to worry about burn-in. BA drivers. They won’t age. Ultimately you’ll get more frequency variation through tip choice, insertion depth and insertion angle than you would if there was such a thing as burn-in. Just enjoy them out of the box
Freefallr4545
- Apr 30, 2011
X2
robertjwarren
voidedsoul
- Jan 31, 2017
My new es3 has got very deep and visible scratches on the shell, Do earsonics provide re-shelling option? Don't want to spend more than 100$ for them
sly_in_the_sky
- Apr 9, 2009
Hello,
You can write to them and they surely will change the shell for free.
