Does anyone use sound isolating earmuffs with earbuds?
My guess is most here (everyone?) have over ear headphones in addition to earbuds. I love my earbuds but only for use in quiet places since I keep the volume at lower levels. I'm going to pick up a pair of "ClearArmor 141001 Safety Ear Muffs " or similar. I have jobs where I'm right next to live music and earplugs don't cut it. I also reckon they'd be good for use with earbuds, and comments from Amazon say that is possible. Of course it would change the sound for better or worse. Likely worse.
I've been testing sound isolating earmuffs for the last few days. I ended up going with
Howard Leight Leightning LOF no. 1013461, I chose these because they are light weight, slim compared to others, look similar to headphones, and are inexpensive. I tested with Monk+ (MP).
Sound: I listened to acoustic, electronic and classical music. At low volumes the MP was very usable. I was walking outdoors in the city.
Comfort: I only wore them for 45 minutes at a stretch and not sure if I'd want to wear longer. They fit snugly and my ears got hot. The outdoor temperature was 54F/12C. During the winter they can function as pretty earmuffs to keep ears warm. But I don't think they will be suitable for hot or temperate weather.
Fit: The headband is wide and adjustable. They can be adjusted to proper height. There is adequate depth to fit standard shell earbud comfortably. Larger earbuds probably won't fit.
Cost: The model tested cost approximately USD$21. Some cost less and others up to $50. Avoid earmuffs that use batteries.
Sound Isolation: Is it dangerous to wear these outdoors? Maybe. the Noise Reduction Rating is 23 for this particular set. Others are higher. 23 is in the ballpark of a standard foam earplug. Low frequency sound can be heard - trucks, helicopters, etc. but at reduced level.
Glasses: Pads are pliant foam so surprisingly comfortable with sunglasses and distance glasses that I tried.
Flying: Haven't tried it but I certainly will in the near future.
Weight and Size: This particular model is very light weight and folds to a compact size. A case isn't included.
Conclusion: If you really want to use your earbuds outdoors in urban environment, sound isolating earmuffs may be an option for minimal duration use. I wouldn't want to wear these for 8 hours, but occupations such as construction require longer duration use. Traditional headphones can be more comfortable but I doubt they offer the same level of sound isolation. Using sound isolating earmuffs is a mixed bag. I don't suggest you get them unless you have another use - such as what they are intended for - protecting your hearing during noisy activities. If you have a dream to wear earbuds outdoors in noisy environments, you may just want to go for it!
