I agree. Do not know why you should try to make up for deficiencies in your hearing via eq. Your brain does it for you automatically. Your deficiencies are part of your hearing, if you try to change that it will sound unnatural! Do you ever think "this sounds wrong" and want to use eq, when you talk to someone or walk along a street and a car passes by?I guess, by creating comfortable conditions for a less sensitive ear, you do not train it (as in ordinary life) and, thereby, provoke an increase in the difference between the ears. (the same for eyes and looking glass, but it's another story)
I don't insist. Don't believe me. Just suggest to research this area.
Earbuds Round-Up
- Thread starter ClieOS
- Tags
- akg akg-k-319-in-ear-bud-headphone-dark-charcoal audio-technica-ath-cm707 baldoor-earbell-e100 bang-olufsen-a8-earphones blox-anv3 blox-m2c blox-tm7 blue-ever-blue-328r creative-aurvana-air-headphones-over-the-ear crossroads-hr1 dunu-alpha-1-hybrid-earbuds-dynamic-balanced-armature-high-fidelity-headphones earbuds hifiman-electronics-es100-vintage-style-earbud-with-15mm-driver-blue rose sennheiser sennheiser-mx-580-stereo-headphones-with-intergrated-volume-control sennheiser-mx-581-stereo-stereo-headphones-with-intergrated-volume-control sennheiser-mx-760 sennheiser-mx-90-style-series-in-ear-headphone-with-volume-control sunrise-audio sunrise-audio-charm venture-electronics-ve-zen yuin-pk1-earphones yuin-pk3-earphones
anli
The only (at the moment) comment here https://aliexpress.ru/item/1005006388297962.html says RW-4000 are "Just as good as the RW-3000".
The Hidizs AP80 Pro X specifications:: Recommended headphone impedance range = 8 to 200 Ohm. You can try the Yinman 600, which may sound fine, but may not get the best out of them with your DAP.Hidizs AP80 Pro X with Yinman 600 is not even to try?
I usually listen to music at a low volume.
fooltoque
To expand on this each ear hear things differently "People's left and right ears are never the same. Each has their own and distinct hearing abilities, reflecting, in fact, the functional asymmetry of our brain. The sounds coming from the right ear are processed by the left cerebral hemisphere and vice versa. While the right hemisphere of the brain is responsible for processing non-verbal sound information, such as pitch, intensity and timbre, the preponderance of the left ear in listening to music and ambient sounds."
The part of the video that kinda blew me away was the effect that head and outer ear shape have on the way we perceive sound through an IEM (and earbud). It starts at 2:50 in the video ("Your ears are why IEMS sound bad"). I had thought that these would be completely taken out of the equation by putting the transceiver close to the ear canal. But I guess the brain basically overlays a filter containing compensation for how your head and ear shape effect sound, and the filter exists no matter where the sound is coming from.
I'm sure many of you were aware of this, but it was a bit mind blowing for me.
I use this feature on my Android sound settings called Adapt Sound in Samsung. It's a very useful tool for volume-matching IEMs, earbuds, and headphones. It works by giving you a frequency test and adjusting each frequency depending on how well you can hear them. I also use them as an at-home audiogram test (I know it doesn't replace a proper test), but it's good enough to get an idea on your hearing health.
Hmm.. my current phone is a Pixel, but I have an older Samsung in my drawer. Might be worth pulling it out for that.
Hmm, that's quite a lukewarm statement. I would have expected the RW4000 to surpass the RW3000 in view of the price and being the so-called sequel. If it is "just as good", that's not a good look TBH. But of course price and release date doesn't naturally mean it will be better, but that would be disappointing if the sequel is just meh.
This is an IEM video, but about 70% of it is directly applicable to earbuds as well. Its a great explanation of why people hear different earbuds completely different, and also why what we see on the graphs may have no relation to how we hear the sound. I learned a lot. Title is so clickbaity though lol.
The audio hobby has both a subjective and an objective component. Objective elements being stuff like measurements, graphs etc.
But there's a huge subjective component for sure, so saying "we all hear differently" is no hyperbole, for these reasons:
1) Hearing Health
Generally the treble frequencies are first to be lost with older age (presbycusis > 50 years old).
I work in the medical line and sign off on audiometry tests daily - please see the graph above on the general hearing range for each age band. It is a physiological phenomenon to lose the higher frequencies as one gets older, sadly. A 17 year old is gonna hear treble very differently from a 70 year old. So sometimes we disagree on forums, with someone saying this earbud is smooth as silk, another saying it is a banshee screaming mess. Both may not be wrong actually.
To complicate matters, some hobbyists suffer from noise induced hearing loss (from occupational or leisure induced), and they lose the 3/4/6 kHz areas first, as the hair cells that transmit these frequencies are found nearer to the outer ear and are the first to die with prolonged loud noise. So these regions generally cover the upper mids and lower treble, which may explain why some folk think something is shouty in upper mids, but someone else disagrees.
2) Fletcher Munson curve - aka volume played at
https://ehomerecordingstudio.com/fletcher-munson-curve/
Music is perceived to be more V shaped (ie boosted treble and boosted bass) at louder volumes. The treble and bass is less pronounced at lower volumes.
Consumers and reviewers hardly mention the volume they use their gear at, so this may be a huge area that affects how we perceive treble and bass.
3) Sources
Some sources are not neutral, and are brighter or warmer, which can influence tonal balance, even on the same earbud.
4) Eartips/Foams/Headpads
Like sources, some tips/foamies/headpads boost or tame treble. Some use naked buds, some use double foaming etc.
5) Ear anatomy
Different ear anatomy may influence sound at the upper mids (pinna gain).
There's an interesting post from Precog about this if you are interested: https://www.head-fi.org/threads/precogs-iem-reviews-impressions.937468/page-94#post-16524009
So in summary, sound is subjective for the above reasons, and how someone hears the same earbud may be a total 180 degrees different from another person. Thus, we should respect others' impressions of a transducer as such. It would also be helpful if we could follow a reviewer or fellow hobbyist who you know shares the same hearing impressions as you do.
Yeah, I think the keyword here that will be of help to @0ostin0 is listening "at low volume". This means that it will probably push them just fine.The Hidizs AP80 Pro X specifications:: Recommended headphone impedance range = 8 to 200 Ohm. You can try the Yinman 600, which may sound fine, but may not get the best out of them with your DAP.
For (let's say) something like 80dB he would only need:
- .20mW
- .35VRMS
- .6A
- 7.467mW
- 2.117VRMS
- .3A (which is a bit short here)
- 20.27mW
- 3.48VRMS
- .8A
VERY good stuff here bro!Hmm, that's quite a lukewarm statement. I would have expected the RW4000 to surpass the RW3000 in view of the price and being the so-called sequel. If it is "just as good", that's not a good look TBH. But of course price and release date doesn't naturally mean it will be better, but that would be disappointing if the sequel is just meh.
1) Hearing Health
3) Sources
5) Ear anatomy
Also let's not forget (where it is most related to earbuds) that flathead earbuds especially actually use the outer ear for the acoustics for the sound being piped into the ear canal. This effect is MUCH more prominent than in headphones and IEMs, because the headphones sit outside your ears, and IEMs go inside your ear canals. I am not saying this isn't true as well for those, but the makeup of the outer ear makes much more difference in the sound with flathead earbuds...
Also let's not forget (where it is most related to earbuds) that flathead earbuds especially actually use the outer ear for the acoustics for the sound being piped into the ear canal. This effect is MUCH more prominent than in headphones and IEMs, because the headphones sit outside your ears, and IEMs go inside your ear canals. I am not saying this isn't true as well for those, but the makeup of the outer ear makes much more difference in the sound with flathead earbuds...![]()
Yep agreed 1000%.
In fact small movements of the earbud in the outer ear will skew the sound signature a lot - that's why earbud graphs are such a mess, and there's no objective database to compare like for like earbud graphs as of now.
^^^ Very true story there...Yep agreed 1000%.
Edit: Though our very own @Ronion was trying to build a database with some of the most common buds (at one point I was going to send him all of my buds for a collected database of graphs that can be a bit more reliable because they all would have come from the same rig and ear).
munchzilla
- Sep 19, 2008
Ohh okay! This is super helpful, thank you.The Yinman can get plenty of volume with less power, they just aren't exerting proper control over the drivers. Some people might even prefer them to sound this way.
The FF5 are not warm and relaxed. They are a bit colder and more aggressive in the treble region (though not sibilant, only comparitively speaking). But, if you want to give them a try, they are indeed TOTL sound, and yes, any set that has detachable cable can be replaced with one that has a mic on it.I only left them off the list because they don't have the sound preference you are looking for (not just sounding like the HD650, but the "warm and relaxed" part; these aren't that).
Yes, you could definitely get the FF1 and FF3S and switch (proprietary) cables for the mic, but from all that I have seen, the FF3S aren't as warm and relaxed as the FF3; though, since I have not heard them, it could be enough for your needs. But the FF1 do fit what you posted that you are looking for.
I didn't suppose you wanted something that sounded just like the HD650, because truly the only one that does is the Yinman 2.0 600. The others on the first list are different, but still warm and relaxing in varying amounts (compared to most other earbuds).
If you are looking for something that is only slightly warm, then that actually changes the recommendations a lot, because most earbuds that have a full sound are on the warm side of neutral. The following are all warm(ish), but some can be more aggressive on the top end than others, but all of them are of good quality to top notch quality (IMHO):
Other than the DIY suggestions, these are all only the ones I have heard or own, so there are probably a LOT more that might fit your needs, and others might be able to speak up with those suggestions. The problem is that there aren't as many (not much more than my first suggestions) that have the combination of warm, plus relaxing, plus either detachable cable, or mic built in.
- Yincrow RW2000 (detach cable)
- Yincrow RW3000 (detach cable; over your budget by quite a bit)
- FiiO FF5 (detach cable)
- FiiO FF1 (detach cable)
- NiceHCK EB2S & pro version (not detach, but has option for mic)
- Lun Shem Aeolian Bells (comes with no cable)
- Smabat ST10S (detach cable; if you can still get them)
- Smabat M5 Golden (detach cable; sound like ICE picks in upper mids though)
- Smabat M4 (same as M5)
- Smabat M2s Pro (discontinued, but have detach cable, and sound really good with the right driver (either Super One 100ohm or ST10S 150ohm driver))
- Most all DIY purchases (as long as you order it with an MMCX or 2-pin connection; and some you can even have them custom tune for you)
- Your own DIY (if you felt like pulling the trigger in making your own set, you can customize it how you like)
- A bunch of budget sets, and you recable yourself (i.e. Monk Lite, Yincrow X6, etc...)
I still think that the Yincrow RW2000 or the FiiO FF1 are my top picks for what you described... My $.02, and I could be way off base here.
I would probably avoid the FF5 then, since I get listening fatigue very quickly...
and likely the FF3S as well then
Looks like RW-2000 is about €150 current price so definitely interested in that one.
I have to admit, I found EB2S/Pro and Yincrow X6 for a really low price too, so I am tempted to try those. with microphone on the cable already.
Don't think I have the time and patience for DIY right now, even if it seems like a lot of fun.
I might start off with the Yincrow X6 and EB2S Pro just to see where I'm at with enjoyment and then try the RW-2000 since they seem to be good options... I found a review of the EB2S on "DMS" channel on youtube and he seems to like both those.
Hope this doesn't sound like a bad idea - maybe I'd be able to try the FF1 as well at some point... just trying not to buy *too many* things
anli
Some thoughts...
If I rotate 2-4 buds pair from 1-2 times a day to each 1-2 days, then overall music impression difference between buds reduces with time (say, after a couple of week). Probably, it is my fantasy.
What is your experience?
fooltoque
Some thoughts...
That's interesting. I haven't tried rotating out so frequently. I usually use 1 pair for a month or more without changing much.
Some thoughts...
At first purchase, I will normally try and listen to a set for at least 2 weeks, if not a month or more to get acclimated with them and what-not... After that, I don't so much think about which set I want to listen to, but instead I put sets into my ears until I find the sound I am looking for (for that day or moment). Some days I will actually go through my whole stock to find the one that sounds good to me at that particular time. Having said that, there are but a couple that don't get much rotation time in this manner. For the most part, though most all of mine get rotation within a week or less, and I still like all of my buds.That's interesting. I haven't tried rotating out so frequently. I usually use 1 pair for a month or more without changing much.
JAnonymous5150
Teaser for the impressions I'll write up tomorrow: The RW-4000s aren't just a revamped RW-3000. Yincrow have really set out to create something that goes beyond comfortably excellent. Did they succeed? We'll get to that tomorrow...
fooltoque
How many likes do we need to reach before you post your review? I'll make more accounts to upvote!
Total: 58 (members: 18, guests: 40)
