I am not sure, if it' the case, i would know more about that Choice
I have these and they work well with CAX. Nonetheless, the other ones from @qua2k seems to be more compact. Really interested now.These are the best I've got, they're flexib
and are perfect for CAX
with the new cable, i need nothing, but with the first one , They are perfect to hear whithout any problem- the CAx 's stand very easely and i can support them as long time as i wantI have these and they work well with CAX. Nonetheless, the other ones from @qua2k seems to be more compact. Really interested now.
Saber 3Hello everybody!
I've been reading the forum occasionally but haven't actually posted anything. I would appreciate if you can help me decide which earbuds to get in the $100-$150 price range. I've narrowed down my search to four models: Fiio FF5, EM5 (used), VE Asura 3.0FE and Rikubuds Saber 3. I'm looking for something that has good build quality and a dark/warm sound, since I'm sensitive to sparky treble.
Based on sound signature, from what I've seen, the best option would be either the Rikubuds or the EM5. The Asura seem more neutral, and the FF5 a bit more V shaped, though I was interesed in these two from a build quality perspective, they look good and well built. I also assumed I could EQ any treble sharpness they might have, or use some thick foams to lower it down.
What would you guys recommend based on your experience? Also I'm open to look for any alternatives in that price range, or cheaper, you might think are a better option.
Thanks!
you already did so much for the forum and more, and even if you would have not, there is really no reason for you to apologize at all! We all have a life, which is more important for sure. Much appreciate the update tho!Okay fellas/ladies, I was gonna post an RW-4k review a few weeks back, but I ended up having to let my account be reviewed and when I started listening I noticed a decent channel imbalance in my pair so I sent them back to exchange them for a new pair. The new pair arrived this morning so I'll do some listening and get my impressions up soon.
BTW, I sincerely apologize for forgetting to post about this after getting my account back. Things have been crazy on the road (happy to be home for a few days) and I didn't remember until the mailman dropped my new pair off this morning. As an aside, VS Audio Store on AE was very easy to deal with and shipped out the replacement with expedited shipping as soon as the returned pair showed up on tracking as being at customs in China. After several less than helpful interactions with sellers on AE, this was refreshing.
Anyways, my plan is to have something posted on Monday or early Tuesday after I've had a few days with them and I promise not to forget this time.
Edit: I hope everyone is doing well!
Edit 2: Added ladies because I figured just because all the active participants I know are dudes doesn't mean there aren't any members of the opposite sex reading the thread. Sorry and welcome to all my female earbuds/flathead fans!
you really nailed it for the FF5! Perfect description!The Yinman can get plenty of volume with less power, they just aren't exerting proper control over the drivers. Some people might even prefer them to sound this way.
The FF5 are not warm and relaxed. They are a bit colder and more aggressive in the treble region (though not sibilant, only comparitively speaking). But, if you want to give them a try, they are indeed TOTL sound, and yes, any set that has detachable cable can be replaced with one that has a mic on it.I only left them off the list because they don't have the sound preference you are looking for (not just sounding like the HD650, but the "warm and relaxed" part; these aren't that).
Yes, you could definitely get the FF1 and FF3S and switch (proprietary) cables for the mic, but from all that I have seen, the FF3S aren't as warm and relaxed as the FF3; though, since I have not heard them, it could be enough for your needs. But the FF1 do fit what you posted that you are looking for.
I didn't suppose you wanted something that sounded just like the HD650, because truly the only one that does is the Yinman 2.0 600. The others on the first list are different, but still warm and relaxing in varying amounts (compared to most other earbuds).
If you are looking for something that is only slightly warm, then that actually changes the recommendations a lot, because most earbuds that have a full sound are on the warm side of neutral. The following are all warm(ish), but some can be more aggressive on the top end than others, but all of them are of good quality to top notch quality (IMHO):
Other than the DIY suggestions, these are all only the ones I have heard or own, so there are probably a LOT more that might fit your needs, and others might be able to speak up with those suggestions. The problem is that there aren't as many (not much more than my first suggestions) that have the combination of warm, plus relaxing, plus either detachable cable, or mic built in.
- Yincrow RW2000 (detach cable)
- Yincrow RW3000 (detach cable; over your budget by quite a bit)
- FiiO FF5 (detach cable)
- FiiO FF1 (detach cable)
- NiceHCK EB2S & pro version (not detach, but has option for mic)
- Lun Shem Aeolian Bells (comes with no cable)
- Smabat ST10S (detach cable; if you can still get them)
- Smabat M5 Golden (detach cable; sound like ICE picks in upper mids though)
- Smabat M4 (same as M5)
- Smabat M2s Pro (discontinued, but have detach cable, and sound really good with the right driver (either Super One 100ohm or ST10S 150ohm driver))
- Most all DIY purchases (as long as you order it with an MMCX or 2-pin connection; and some you can even have them custom tune for you)
- Your own DIY (if you felt like pulling the trigger in making your own set, you can customize it how you like)
- A bunch of budget sets, and you recable yourself (i.e. Monk Lite, Yincrow X6, etc...)
I still think that the Yincrow RW2000 or the FiiO FF1 are my top picks for what you described... My $.02, and I could be way off base here.
They came included with the CAX when I purchased it from @jwilliamhurst I am hoping he can let us know where he got themMind sharing a link to the silicon wings ?
They came included with the CAX when I purchased it from @jwilliamhurst I am hoping he can let us know where he got them![]()
It’s these in black size SI have these and they work well with CAX. Nonetheless, the other ones from @qua2k seems to be more compact. Really interested now.
I assume you just got them??? If so then, congrats on your new shiny!Kgis p13 pro
Smooth sounding, thin bass and treble but gorgeous mids, resolution and soundstage above average, one of the best mids under $25
Yea got them 1 week ago, cost around $7 and sounds better than boarseman mx98s, similiar mids/vocal oriented buds, but with far better technicalities. I wonder how the pricier kgis sound is, especially the sp500I assume you just got them??? If so then, congrats on your new shiny!
Those look very nice (especially for a set under $25). Are you wearing them without any foams?
looks gorgeous! this morning i caught myself seriously thinking about moving to asia because of the endless earbud possibilitys to get. those buds will be unavailable in europe for ever. i think i have a serious problemKgis p13 pro
This is an IEM video, but about 70% of it is directly applicable to earbuds as well. Its a great explanation of why people hear different earbuds completely different, and also why what we see on the graphs may have no relation to how we hear the sound. I learned a lot. Title is so clickbaity though lol.
I guess, by creating comfortable conditions for a less sensitive ear, you do not train it (as in ordinary life) and, thereby, provoke an increase in the difference between the ears. (the same for eyes and looking glass, but it's another story)I use this feature on my Android sound settings called Adapt Sound in Samsung. It's a very useful tool for volume-matching IEMs, earbuds, and headphones. It works by giving you a frequency test and adjusting each frequency depending on how well you can hear them. I also use them as an at-home audiogram test (I know it doesn't replace a proper test), but it's good enough to get an idea on your hearing health.
