Earbuds Round-Up
Oct 19, 2021 at 10:58 PM Post #58,201 of 59,156
assassin10000
CA
wow, u can mod it using mmcx?! thats cool, because it use metal shell and very small housing, im very impressed!!
what is the meaning of red film driver? u change the original driver?
Yep. It's a bit more difficult than other MMCX mods, but I wanted this shell with an MMCX connector. Since K's didn't do it, I had to. :wink:
Correct. I changed the driver as well. The only thing original on that pair is the shell/housing.
Oct 20, 2021 at 3:48 AM Post #58,202 of 59,156
Ronion
Thanks for trying to save me from too many losses. I'm not going to order the LBBS since I can't bother with eq at this time. Maybe when I receive my Nicehck order I'll have renewed vigor.
Added a couple Vido buds to my order. This person believes they compare favorably. So cheap, worth trying.
That LBBs sounds great without EQ. I’ve really never felt the need to EQ it.
Oct 20, 2021 at 5:50 AM Post #58,203 of 59,156
WoodyLuvr
Friend of Blur Earphones
siam
PEQ means parametric equalizer or is PEQ the name of an earbud? Can't I PEQ many different earbuds to sound similar? Are the K's LBBS that much more resolving? ... details, transients, impact, lacking offensive ringing, etc etc
Yes, parametric eq.
You can't just eq anything into the x6...
The LBBS is possible because of how good It already is and how well it responds to eq.
No. Unfortunately, most earbuds do not respond very well to EQ unless very minor adjustments. Sometimes it is due to an inherently strong house tuning and other times due to restrictive limitations of the particular driver and the dampening being used. Instead of using EQ heavily, to change the overall character signature of an earbud, you should EQ lightly to ever so slightly tame and/or emphasize certain aspects of an earbud's signature. Plus, it must be heavily stressed, @RikudouGoku really, really knows what he is doing and as he has clearly stated on many posts in this here thread he has only been successful in EQ'ing the Ks LBBs to sound like a god-tier level X6... deserving a huge bravo for the accomplishment!
Oct 20, 2021 at 6:07 AM Post #58,204 of 59,156
Scuba Devils
Ireland
Has anyone tried the Cayin N6ii with R01 board with buds? I'm buying one and from impressions I've read, I think it will drive them well. The n3pro with the tube amp sounds very interesting too...
Oct 20, 2021 at 6:42 AM Post #58,205 of 59,156
ian91
UK
IIRC, @Charlyro222 has the N3Pro, maybe he can comment on that one?
Oct 20, 2021 at 7:14 AM Post #58,206 of 59,156
RikudouGoku
Sweden
Definitely. EQ is only needed if you want the X6 sound.
Oct 20, 2021 at 8:37 AM Post #58,207 of 59,156
Charlyro222
SPAIN
Yes, definetly N3Pro is an affordable Tube Dap that can "sweet" everything you put it on.
It depends more on the kind of music you listen to.
I like smooth jazz with male and female vocals and Blur earbuds are great on that, but at the cost of some resolution.
The way to go for me are R2R Dacs/Amps.
Oct 20, 2021 at 11:09 AM Post #58,208 of 59,156
irv003
Member of the Trade: BBB/Bisoy Buds
USA
n6ii r01 sounds good with dynamic drivers. you will like it.
w/ shozy BK
Oct 20, 2021 at 12:56 PM Post #58,209 of 59,156
Philimon
Portland
That and sound signature. The older LB/LBB is a warm, smooth but still detailed sound signature.
The LBBs is a more V-shaped signature that doesn't go too far in its upper mid/lower treble boost.
The LBBs is also available as 'white' with a plated cable or with mic which has a black cable sans the braiding. I bought the mic version last sale for about $25 iirc.
No audible or measurable difference in sound w/mic, when I checked it.
Can the current issue of LBBs be modded to sound like old "warm" LB/LBB? Is the old LB/LBB still available for order?
Oct 20, 2021 at 1:36 PM Post #58,210 of 59,156
assassin10000
CA
I'm doubtful that is possible, given the different drivers. But maybe.
You'd have to ask sellers if they have old stock and verify the serial number (1st 2 numbers are the build year iirc).
Oct 20, 2021 at 2:19 PM Post #58,211 of 59,156
foniak
earth
w/ shozy BK
How do they compare to Yuin PK3 or EB2? looks like what I want, nice old school design earbud that sounds great like PK3 and EB2 sounded, but they are too expensive, not sure if justified, considering how cheap and good PK3 and EB2 sounded, unfortunately both stopped working in one side. Im looking for an alternative.
Oct 20, 2021 at 2:28 PM Post #58,212 of 59,156
irv003
USA
i never tried those but these shozy BKs are balance/neutral sounding which leans on the warm side. i think its one of the best PK shell buds out there or i have tried. I got this unit last 2017 and still keeping it. it has good bass for a PK shell buds.
Oct 20, 2021 at 8:47 PM Post #58,213 of 59,156
1clearhead
Thanks. I was able to figure out how to change the website to english. But checking out wouldnt complete using my iPhone. Website kept getting stuck loading… Im going to try ordering using my macbook. But before I do is there any differences between Yincrow X6 versions? If I recall correctly some sellers note “latest version” or “2018 version”. Nevermind, Ill just order the one you directly linked for me. Thanks again!
Sorry I couldn't help you earlier. Since I work and live in China, chances are I was sleeping in this side of the world. But, I can say that all the suggestions given to you by fellow head-fiers should work fine for you. Though, according to what you were looking for in your taste of sound signature, either the Yincrow X6 or Yincrow RW-9 should do just fine.
Have fun listening, cheers! :beerchug:
-Clear
Oct 20, 2021 at 9:10 PM Post #58,214 of 59,156
tgx78
Vancouver, Canada
Blur MX64 STE and FD7 for tonight’s listening session.
Oct 21, 2021 at 8:20 PM Post #58,215 of 59,156
Sam L
San Francisco Bay Area
hearing great things about the lbb. I need to get a pair and see how they measure and respond to autoeq/wavelet analysis.
**edit** lol... reading my own signature, I realize I have a pair somewhere. hmmm I just need to find them....
