Earbuds Round-Up
Jun 30, 2021 at 2:03 AM Post #55,636 of 59,061
WoodyLuvr
Friend of Blur Earphones
siam
If you go with the 2.5 balanced version, the E1DA 9038SG3 have enough power to drive high impedance earbuds. It works with ios gear, though you have to get the cable separately.
For desktop use I am very happy with the E1DA PowerDAC v2, this one would need external power to function optimally with a mobile device. Though you get even more power and a parametric EQ for free.
Both sound great and are an excellent value.
No issue regarding noise with lower impedance high sensitivity earbuds on the PowerDac?
@sfrsfr Not meaning to harp but I am indeed extremely interested in hearing your thoughts and experience regarding noise and low impedance high sensitivity earbuds with your E1DA PowerDac v2. Any insight would be most appreciated. Cheers.
Jun 30, 2021 at 2:15 AM Post #55,637 of 59,061
40760
I too was looking at the E1DA after that few previous mentions...
I'm looking for a small footprint DAC that can drive my higher impedance (320ohms) earbuds for desktop use.
Jun 30, 2021 at 3:07 AM Post #55,638 of 59,061
sfrsfr
Okinawa
I'm sorry but I can't answer this as the lowest impedance gear that I own and can connect to the PowerDAC is Tri I3, which is a 15Ω iem. No issue with noise in this case, it makes a great combo.
The PowerDAC's output impedance is 1.5Ω, so it should be fine with anything that has impedance >12Ω.
I am a fan of E1DA engineering and the PowerDAC is surely their best value.
Anyway, are there any interesting low impedance high sensitivity buds to consider?
It seems to me that the sweet spot for good sounding earbud drivers is around 150Ω...
But I'm newbie to earbuds, so looking for more surprises!
Jun 30, 2021 at 3:33 AM Post #55,639 of 59,061
PapyKahan
France
I use a Luxury and Precision W2 for the same use case.
I also own a PowerDAC V2. It's volume control trough a Bluetooth app is a no go for me.
Jun 30, 2021 at 3:38 AM Post #55,640 of 59,061
FranQL
Spain
Soon E1DA Cosmos dac will be released for desktop.
Dual ES9038Q2M
OPA1622 with +/-7.5V i.e. 3.5Vrms at >50ohm
Jun 30, 2021 at 3:48 AM Post #55,641 of 59,061
baskingshark
Jabberwock Island
Thanks for the info. Read lots of good things about the PowerDAC, hope to try it one day!
TRI I3 is not really a good gauge for hiss though, cause it has a planar inside and planars are generally harder to drive than conventional drivers. Indeed, TRI I3 is one of the harder to drive IEMs actually, and some lower end amps can't do the sound justice. But I think E1DA gear and PowerDAC should have no issues.
I think a high sensitivity plays a big role in hiss, more so than a low impedance, so that's the main specification we should be looking at when it comes to noise floor and hissing.
You can try a cheap RY4S 300 ohm set, it does need amping, but it is quite a nice U shaped set, not the best technicalities but quite good for the price of $13 - 15 USD.
Jun 30, 2021 at 4:29 AM Post #55,642 of 59,061
sfrsfr
Okinawa
In that case JCALLY EP09 with sensitivity of 139 (dB) are the highest sensitivity buds I have. No noise issue here either, though they distort as hell when trying the PowerDAC PEQ.
Still my best combo with the PowerDAC is SFR PT2021 365ohm, which take equalization really well so that makes them quite versatile.
Btw. I have the RY4S 300ohm and enjoying it!
Jun 30, 2021 at 4:31 AM Post #55,643 of 59,061
WoodyLuvr
siam
FYI the new PowerDAC V2.1 offers UAC2 HW volume enabled by the CT7601 USB Bridge so it can be adjusted via Windows :wink:
Jun 30, 2021 at 5:02 AM Post #55,644 of 59,061
WoodyLuvr
siam
Thank you, that was exactly what I was looking for... now I am seriously considering the E1DA PowerDAC v2.1 again. Just need to figure out the solution for this wonky 2dB volume increments on my keyboard scroll wheel:thinking:. Just successfully solved this with an Autohotkey (.ahk) script, now I got me 1 dB increments on my volume wheel baby :smiley:!
Strangely the listed sensitivity rating is all over the map... ranging from 128dB to 139dB. I did find what appears to be an official spec sheet from JCALLY which lists a sensitivity @ 128dB but it doesn't list if that measurement is dB/mW or dB/V.
Not surprising that the JCALLY EP09 isn't playing well with PEQ and power... the driver is most likely being pushed well beyond it's rated specs! See the tables below. If indeed 128 dB/mW one (1) measly volt is pushing those little drivers to over 142dB SPL! And if 128 dB/V it is still at an ear shattering 128dBSPL! With such high driver sensitivity I wouldn't be surprised if the max input power rating was something like 50-60mW with a recommended rated power of only 15-20mW!
if dB/mW (left table) ******** if dB/V (right table)
Jun 30, 2021 at 5:47 AM Post #55,646 of 59,061
WoodyLuvr
siam
Dual ES9038Q2M
Also on my consideration list but "the wait" may kill me 💀☠️⚰️! And I am not getting any younger!
Jun 30, 2021 at 6:00 AM Post #55,647 of 59,061
furyossa
Serbia
Yes, besides heavy metal Willy is/was into binaural recordings perhaps explaining why it crept into his house tuning :wink: .
Hmmm :thinking: ... yup... I definitely need to try these:wink:
Jun 30, 2021 at 6:28 AM Post #55,648 of 59,061
jrazmar
Anyone here knows where to buy Seahf earbuds? Are they still making new earbuds? I was looking through my old hand bag that I used to bring to office before and was so surprised to find some old earbud stuff including a Seahf LD-3.0, Cygnus, EMX500 and Vido. I did a quick listen to each to check if they are still working and all are fine. However, of all these, I was not expecting to love the sound coming from the Seahf. It's not fancy-looking but the sound is so natural, airy and balanced. I already forgot that it sounded this good and no matter what genre I toss it, it can play beautifully. I am hooked and it is now my daily driver giving my Turandot a nice vacation. :ksc75smile:
Jun 30, 2021 at 7:17 AM Post #55,649 of 59,061
SiggyFraud
